Kinetic Maintainers,
We’re getting ready for another Kinetic sync.
We have 157 packages to sync.
However there’s currently 12 regressions: http://repositories.ros.org/status_page/ros_kinetic_default.html?q=REGRESSION
There look to be two separate trees of failures. Since this may take a few iterations to resolve I will plan to hold for new releases next week on Wednesday for a targeted sync on Friday. If there’s been no progress by Tuesday I’ll start reverting the recent releases to resolve the build failures.
Regression #1
The first build failed here:
http://build.ros.org/view/Kbin_uX64/job/Kbin_uX64__pilz_control__ubuntu_xenial_amd64__binary/9/
Started by upstream project Kbin_uX64__joint_trajectory_controller__ubuntu_xenial_amd64__binary build number 78
originally caused by:
Started by upstream project Ksrc_uX__joint_trajectory_controller__ubuntu_xenial__source build number 12
Started by upstream project Krel_trigger-jobs build number 91931
Started by timer
Started by timer
Started by upstream project Kbin_uX64__realtime_tools__ubuntu_xenial_amd64__binary build number 30
Started by upstream project Ksrc_uX__realtime_tools__ubuntu_xenial__source build number 5
Started by upstream project Kbin_uX64__control_toolbox__ubuntu_xenial_amd64__binary build number 39
This looks to have been caused by either a release of joint_trajectory_controller
or realtime_tools
@bmagyar This looks like the release that caused the regression: https://github.com/ros/rosdistro/pull/20262
@agutenkunst Could you look at what might be causing this issue as well?
Regression #2
The other regression appears to be caused by a new package in the open_manipulator release that’s failing to build but was also added as a dependency for other existing packages.
@Pyo The release at issue appears to be https://github.com/ros/rosdistro/pull/20264
