We have 59 new and updated packages and no regressions.
I plan to hold new releases for Kinetic until Thursday and make the sync then.
If there’s anything that would be a concern with this plan please reply here.
We’re working on making the rosdistros more accurate in representing what is available. And to that end we’re implementing a new prototype tool which audits the packages released. It has identified the following packages as failing to build. Before the coming sync I plan to ticket and remove all of the following since they are not building.
They have not been flagged as a regression because most of them have never built.
Prepared for configuration: https://raw.githubusercontent.com/ros-infrastructure/ros_buildfarm_config/production/index.yaml
Prepared for rosdistro index: https://raw.githubusercontent.com/ros/rosdistro/master/index-v4.yaml
Release should be rolled back:
Packages should be blacklisted:
Removing packages not building on any platform
Blacklisting packages on specific architectures:
The sync is out:
