Raspberry Pi 5 Stereo Vision
Since the raspberry Pi 5 has two camera ports, and Picam modules are inexpensive, I am wondering if any one has successfully set up a stereo vision node using camera_ros or something similar?
To use two independent camera’s for stereo vision you would need:
  1. Synchronize capture start of the two sensors, which is typically done with hardware. The start capture pulse or command would need to be issued to the cameras with <50us jitter between each camera
  2. Software to keep the exposure, and white balance of each camera the same, programmed during the vertical blank when the sensor is not capturing data.
  3. A rigid assembly with mechanical tolerance for vibration, shock, and thermal changes, for extrinsic calibration between the camera’s that remains valid over some time interval.
  4. Calibration software for extrinisics between the two camera’s.
  5. Intrinsic + extrinsic calibration per camera.
  6. Sufficient compute or hardware acceleration for a stereo matching algorithm or AI perception function.
The effort involved may quickly exceed the cost savings of the cheap camera.
Thanks. It would seem that a better use of two cameras is to separate tasks,
perhaps one camera used for fiducial markers, and another used for Yolo object recognition.
