ROS 2 Reinforcement learning
For some time, I have been working on a basic reinforcement learning playground designed to enable experimentatio with simple systems in the ROS 2 environment and Gazebo.
Currently, you can try it with a cart-pole example. The repository includes both reinforcement learning nodes and model-based control, with full calculations provided in a Jupyter notebook. The project also comes with a devcontainer, making it easy to set up.
You can find the code here: GitHub - Wiktor-99/reinforcement_learning_playground
Video with working example: https://youtube.com/shorts/ndO6BQfyxYg
Hi @Wiktor-99, I was wondering are you using Gazebo Classic for this project? If that is the case, is there any plans for updating the packages to use Gazebo Harmonic/Ionic ?
Hi, I used latest gazebo and jazzy distro
