What is the best development IDE choice for ROS C++ development? I see here Eclipse IDE being recommended - http://wiki.ros.org/IDEs. However, some of the developers in our organization want to use QTCreator for ROS C++ development.
How they both compared for primarily ROS centric development works?
Please share your experience and thoughts.
Thanks.
Iâve used both Eclipse CDT and QtCreator for ROS C++ development. Both work without problems. I personally prefer QtCreator now because it feels a bit snappier.
Note that the IDEs page youâve linked to also has instructions on how to use QtCreator with ROS. It also doesnât specifically recommend Eclipse over QtCreator.
At our lab most people tend to use the two mentioned by Martin (QtCreator and Eclipse CDT), but recently Iâve tried and also heard good things about CLion: https://www.jetbrains.com/clion/
The thing that I like about CLion is the clean and clever integration with CMake, and that it âjust worksâ with ROS packages without having to do special configuration (as long as you are running it from a console that has the ROS environmental variables).
Iâve been using Eclipse for C++ and not through CMake. Going to look at CLion mentioned by Alexis in another message since it integrates with CMake. I donât like having to add files to the CMake system that Eclipse already knows about. The trade off hassle is finding the libraries needed for linking. But so far itâs worked well for me. Iâve avoided having to go back and retrofit my builds into CMake.
One semi snide comment is that the best IDE is the one you know.
Yes, exactly the same is true for QtCreator. Since all Catkin packages are just plain CMake projects (catkin is just a set of CMake macros), it all just works without any extra steps required when the ROS environment variables are set.
QtCreator is a good choice. But I donât think that is the best one.
I kind of like ClionâŚbut it takes ages to open. I tend to close the IDE by mistake once in a while and is fully annoying to wait until it opens again. Also I have the feeling that drains your computer resourcesâŚSometimes is only open it and start hearing the fun of the computer spinning. And of course, you have to pay for it.
RoboWare had a nice idea behind, but I cannot edit .launch or .xml as freely as it should. Feels like that it requires time to grow up.
Right now I am playing with Visual StudioâŚI am happier. Free, fast to open, smoothâŚI am using it since only 3 weeks but I feel that it deserves at least a try.
I found that QtCreatorâs build-in cmake integration works great with ROS projects (both catkin_make and catkin tools), but make sure you check out the ROS IDSâs wiki linked above for how to set things up.
I havenât had a great solution for a while, but I do use Eclipse w/ âeclipsifyâ to help get a lot of the references working (still build with catkin tools though).
For anyone using Eclipse (who hasnât already battled to set it up), I highly recommend âeclipsifyâ from ethz-asl, to give you a jump-start in creating configured Eclipse projects for your catkin pkgs:
I just checkout eclipsify (and their other dependency catkin_simple) into my ws, build, and run the tool over a catkin list of the projects I have checked out, and it will generate eclipse projects for you to Import, which start with some good settings they have discovered. You probably want to make a separate â/projects/â dir to output the projects into, rather than the default â/devel/â, so a clean doesnât blow away your projects.
I still tweak it a bit, but it resolves a lot of the dependencies, which I find one of the most useful IDE features for me personally: I make sure to setup âShare settings/resources between projectsâ, make sure the C++11 flag is set, and include the /opt/ros/ include+lib dirs for my main projects, to help the resolution along.
Are you using Visual Studio on Windows or Visual Studio Code (https://code.visualstudio.com/) on a Linux machine? I tried Visual Studio Code a while back (6 months ago?) and was unimpressed, but maybe itâs improved since then.
On a Linux machine. Works perfectly with my ros workspaces, and you can activate a console where you can perform your catkin_make and compile directly. As I said, still trying, but I am happy right now.
I also use Eclipse in combination with catkin tools (http://catkin-tools.readthedocs.io/en/latest/installing.html), the config is set to create eclipse projects:
catkin config --cmake-args -G"Eclipse CDT4 - Unix Makefiles" -D_ECLIPSE_VERSION=4.6 -DCMAKE_BUILD_TYPE=Debug
This then creates a single project from each ROS package in the build folder of the workspace. In Eclipse you just need to import those you want to have in your workspace.
For me this is the best and easiest way to use Eclipse with ROS I discovered so far.
Using the normal catkin_make with the arguments above, you will always import all the packages in the workspace as one huge Eclipse project, which is not so nice in my opinion.
Nice, you might want to link the tutorial from the ROS wiki IDEâs page.
Just a small nitpick:
Cliking on build is equivalent to calling :
cd /path/to/catkin_ws
catkin build my_super_project
I would assume that this is not correct, since catkin build my_super_project also builds dependent projects. Maybe it is similar to running catkin build my_super_project --no-deps.
If you try CLion as mentioned above (at least with a good workstation) itâs hard to go back to your previous IDE. It worths the money if you have enough RAM on your PC.
If you are skeptical, just try itâs debugging and refactoring features.
