[SLAM] New 3D LiDAR odometry, mapping and localization packages
Hi friends!
Today, all active ROS 2 distributions finally ship the brand-new mola_lidar_odometry package, featuring 3D LiDAR odometry & mapping from either, the most “famous” datasets (KITTI, MulRan,…) or your own ROS bags or a live robot. It can be run via a CLI, a custom GUI, or from RViz or FoxGlove.
That is just one package from an “ecosystem” of C++ libraries, ROS packages, and CLI and GUI tools, part of an attempt to “change the mindset” towards using view-based maps (dubbed simple-maps in our framework), which can then be used to generate metric maps of different types, filter them, etc. with pipelines defined as YAML files (no coding needed at all!). The core insight is: the same “simple map” should be used to generate different metric representations depending on the desired robotic task: navigation, manipulation, perception, and so on.
The LiDAR odometry algorithm itself can be fully reconfigured via a YAML file too, and extended via a plugins mechanism to define new metric map types, raw sensory data matching algorithms, etc.
This video summarizes some results and features of the project:
Interested users should probably head to:
I’m thriving to see what feedback the ROS community gives about all these tools. Feel free of opening issues and/or pull requests in the project repos, and share your successes (or issues!) trying it with your own robotic projects! :fire::fire:
Of course, it’s an ongoing project and new features are planned for the short term, so stay tuned for more news.
JL
Hey! Great work, looks exciting.
Any chance there’s a plan to support Noetic at some point?
Hi! To be honest, at the beginning of the project I expected nobody would care about ROS 1 by this date… but that’s clearly not the case.
Roughly 90% of the project codebase is already on Noetic (mrpt_lib* packages, mp2p_icp, mola_common).
The rest would require some thinking, specially because I hate maintaining different git branches for different distros, but there must be a way.
So, yes, it might be possible to backport it to ROS 1 at some point.
