Donate your rosbag (Cloudini benchmark)
as my presentation about Cloudini was accepted at ROSCon 2025, I want to come prepared with an automated benchmarking suite that measure performance over a wide range of datasets.
You can contribute to this donating a rosbag!!!
Thanks for your help. Let’s make pointcloud smaller together :pinched_fingers:
How to
Data Donation Disclaimer: Public Availability for CI Benchmarking
By donating your data files, you acknowledge and agree to the following terms regarding their use and public availability:
Purpose: The donated data will be used for research purposes, specifically to perform and validate benchmarking within Continuous Integration (CI) environments.
Public Availability: You understand and agree that the donated data, or subsets thereof, will be made publicly available. This public release is essential for researchers and the wider community to reproduce, verify, and build upon the benchmarking results, fostering transparency and collaborative progress in pointcloud compression.
Anonymization/Pseudonymization: Please ensure that no personally identifiable information is included in the data you submit, as it will be made public as-is.
Can I give it to you in person at ROSCon?
I will warn you that I already get pretty good compression on my bags.
I saw this list before in this thread: Rosbag dataset hub, thanks @Katherine_Scott and @avatar042 for putting this together.
It contains some public available datasets like Spot robot validation data
However, there are a lot of ROS1 bag though… so I don’t know if they are what you are looking for.
Just submitted a GH issue and starred your repo! I know some people who are also struggling with point cloud compression. Keep up the good work!
nice. I will have a look for sure :slightly_smiling_face:
Anyway, if people want to make sure that I optimize for their data, they can still contribute!
The compression ratio is affected a LOT by the kind of PointCloud2 fields being used.
Someone already knew…
