Installation of ROS/ROS2 on PYNQ
I would like to share a quick guide to install ROS/ROS2 on Pynq OS, which is based on Ubuntu, Python Jupiter-notebook, and has the functionality of handling the FPGA interface by Python on Xilinx Zynq.
I used Zybo-Z7-20 and PYNQ 2.3 to verify the following instruction.
Please check the latest information to create an SD-card image of PYNQ OS for your target board, for example:
https://pynq.readthedocs.io/en/v2.5.1/index.html
*** 1. Install ROS (melodic, desktop)
Follow the instruction on ROS.org with the following modification.
melodic/Installation/Ubuntu - ROS Wiki
At “1.2 Setup your sources.list”, however, the (lsb_release -sc) will return "trinity" on Pynq. So please rewrite (lsb_release -sc) to “bionic” as follows:
$ sudo sh -c ‘echo “deb http://packages.ros.org/ros/ubuntu bionic main” > /etc/apt/sources.list.d/ros-latest.list’
#You can modify the part in the file “/etc/apt/sources.list.d/ros-latest.list” if you already did it with “trinity”. Please replace “trinity” with “bionic”.
The remaining commands work as it is.
Please install
Desktop Install: ROS, rqt, rviz, and robot-generic libraries
by
$ sudo apt install ros-melodic-desktop
Then the simplest talker/listener example works by the following:
http://wiki.ros.org/ROS/Tutorials/CreatingPackage
http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber(c%2B%2B)
or
http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber(python)
In this case, you need to run “roscore” for master node.
*** 2. Install ROS2 (eloquent, desktop)
<no title>
Again, at “Setup Sources, And then add the repository to your sources list:”, the $(lsb_release -cs) should be replaced with “bionic” as follows:
sudo sh -c 'echo "deb [arch=(dpkg --print-architecture)] http://packages.ros.org/ros2/ubuntu $bionic main" > /etc/apt/sources.list.d/ros2-latest.list’
#You can modify the part in the file “/etc/apt/sources.list.d/ros2-latest.list” if you already did it with “trinity”. Please replace “trinity” with “bionic”.
To install ros-eloquent-desktop, the fast-rtps requires libssl1.1 (>=1.1.1) although the 18.04 bionic (armhf)'s version is libssl1.1.0g.
You need to add bionic-updates repository to /etc/apt/sources.list.d/multistrap-bionic.list
deb Index of /ubuntu-ports bionic-updates main
So it looks like:
xilinx@pynq:~$ cat /etc/apt/sources.list.d/multistrap-bionic.list
deb [arch=armhf] Index of /ubuntu-ports bionic universe main
deb-src Index of /ubuntu-ports bionic universe main
Then, please install
Desktop Install (Recommended): ROS, RViz, demos, tutorials.
by
$ sudo apt install ros-eloquent-desktop
Then, you can simply run the simplest talker/listener built-in example by:
ros2 run demo_nodes_cpp talker And in another terminal: ros2 run demo_nodes_py listener
In this case, you don’t need to run a master node like “roscore” because the master node is distributed in ROS2.
Hey, did you ever try installing rod foxy or humble ?
