when i clicked lidar_point_pillars buttton ,runtime manager.
get a error,
[lidar_point_pillars.launch] is neither a launch file in package [lidar_point_pillars] nor is [lidar_point_pillars] a launch file name
The traceback for the exception was written to the log file
. install/local_setup.bash
but it did not work.Please help.Thanks.
Hi @liuliu758,
Please use ROS Answers for technical questions and be sure to read the Guidelines for asking questions here: http://wiki.ros.org/Support#Guidelines_for_asking_a_question_.28Please_read_before_posting.29
Thanks!
This is an Autoware-related question and currently we are doing Autoware support here on Discourse.
Please check the result of
colcon build --packages-up-to lidar_point_pillars
There is possibility that you did not build lidar_point_pillars
because lacking of dependency like TensorRT
, CUDA
and CuDNN
