New Foxglove Extension - Joystick Panel
Hi everyone, three years ago I posted this topic and after working on it for a couple of days each year, I’ve finally made a first release of my Joystick Panel for Foxglove. You can find the repo here and below is a short video demonstration - I will be making a full “Articulated Robotics” video once I have cleaned up some bits and pieces.
You can check out the readme for a few different use cases that are covered, but the primary one is to provide an easy way to receive Joystick input from a device that may not otherwise be running ROS, and integrate that into the monitoring suite provided by Foxglove.
Unfortunately I am having some troubles running it on mobile devices (my original use case) but I’m sure I will be able to work that one out, any advice will be appreciated - Github issue here.
I hope some of you will find this helpful - I think @kneave mentioned wanting something like this?
Absolutely amazing timing, thank you for saving me a job and likely doing a far better job than I would’ve done too! :sweat_smile:
Keep up the good work on your videos too, informative for sure!
Thanks! And I should say - if you want to use it with the Steam Deck, make sure you:
  • Have it sending native controller input (e.g. with opensd)
  • Modify mapping1.json which is currently set up for a different controller (it should work without this but the display will be weird)
You absolute legend, I had no idea OpenSD existed and have been trying to figure out how to access the trackpads and buttons without faffing with remapping for ages!
Josh! You are the man! I’ve been following/learning from your Articulated Robotics channel for some time now & just getting started on implementing Foxglove on the Steam Deck to accompany a rather large A.I. training robot I’ve been constructing for my non-profit over the past year. Thank you so much for your effort & open source contributions sir!
