We’re happy to announce new packages and updates for Foxy Fitzroy!
This sync includes the release of CycloneDDS 0.7.0, with support for DDS security as well as performance improvements for large messages. Note, it includes changes to some binary interfaces, so it is possible you may run into ABI compatibility issues using cyclonedds directly. There should be no issues using the RMW interface. For more info, see https://github.com/ros2/ros2/pull/999.
Package Updates for foxy
Added Packages [20]:
- ros-foxy-autoware-auto-msgs: 0.1.0-1
- ros-foxy-can-msgs: 2.0.0-1
- ros-foxy-casadi-vendor: 3.5.1-1
- ros-foxy-dolly: 0.3.0-1
- ros-foxy-dolly-follow: 0.3.0-1
- ros-foxy-dolly-gazebo: 0.3.0-1
- ros-foxy-dolly-ignition: 0.3.0-1
- ros-foxy-eigenpy: 2.5.0-1
- ros-foxy-grbl-ros: 0.0.2-4
- ros-foxy-lgsvl-bridge: 0.1.2-1
- ros-foxy-mavlink: 2020.8.8-1
- ros-foxy-nav2-system-tests: 0.4.3-1
- ros-foxy-plotjuggler-msgs: 0.1.2-1
- ros-foxy-ros-ign: 0.221.1-1
- ros-foxy-ros-ign-bridge: 0.221.1-1
- ros-foxy-ros-ign-gazebo: 0.221.1-1
- ros-foxy-ros-ign-gazebo-demos: 0.221.1-1
- ros-foxy-ros-ign-image: 0.221.1-1
- ros-foxy-system-metrics-collector: 0.1.0-1
- ros-foxy-vision-msgs: 2.0.0-1
Updated Packages [68]:
- ros-foxy-connext-cmake-module: 1.0.0-1 -> 1.0.1-1
- ros-foxy-costmap-queue: 0.4.1-1 -> 0.4.3-1
- ros-foxy-cyclonedds: 0.6.0-1 -> 0.7.0-1
- ros-foxy-dwb-core: 0.4.1-1 -> 0.4.3-1
- ros-foxy-dwb-critics: 0.4.1-1 -> 0.4.3-1
- ros-foxy-dwb-msgs: 0.4.1-1 -> 0.4.3-1
- ros-foxy-dwb-plugins: 0.4.1-1 -> 0.4.3-1
- ros-foxy-gps-msgs: 1.0.3-1 -> 1.0.4-1
- ros-foxy-gps-tools: 1.0.3-1 -> 1.0.4-1
- ros-foxy-gps-umd: 1.0.3-1 -> 1.0.4-1
- ros-foxy-gpsd-client: 1.0.3-1 -> 1.0.4-1
- ros-foxy-kobuki-dock-drive: 1.1.0-1 -> 1.1.1-1
- ros-foxy-kobuki-driver: 1.1.0-1 -> 1.1.1-1
- ros-foxy-libcurl-vendor: 2.3.2-1 -> 2.3.3-1
- ros-foxy-nav-2d-msgs: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav-2d-utils: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-amcl: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-behavior-tree: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-bringup: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-bt-navigator: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-common: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-controller: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-core: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-costmap-2d: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-dwb-controller: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-gazebo-spawner: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-lifecycle-manager: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-map-server: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-msgs: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-navfn-planner: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-planner: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-recoveries: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-rviz-plugins: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-util: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-voxel-grid: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nav2-waypoint-follower: 0.4.1-1 -> 0.4.3-1
- ros-foxy-navigation2: 0.4.1-1 -> 0.4.3-1
- ros-foxy-nodl-python: 0.2.0-1 -> 0.3.0-1
- ros-foxy-py-trees: 2.1.0-1 -> 2.1.1-1
- ros-foxy-resource-retriever: 2.3.2-1 -> 2.3.3-1
- ros-foxy-ros2nodl: 0.2.0-1 -> 0.3.0-1
- ros-foxy-rosidl-adapter: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-cmake: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-generator-c: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-generator-cpp: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-parser: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-runtime-c: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-runtime-cpp: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-typesupport-connext-c: 1.0.0-1 -> 1.0.1-1
- ros-foxy-rosidl-typesupport-connext-cpp: 1.0.0-1 -> 1.0.1-1
- ros-foxy-rosidl-typesupport-interface: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-typesupport-introspection-c: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rosidl-typesupport-introspection-cpp: 1.0.1-1 -> 1.1.0-1
- ros-foxy-rqt-image-view: 1.0.4-1 -> 1.1.0-1
- ros-foxy-rqt-robot-monitor: 1.0.1-1 -> 1.0.2-1
- ros-foxy-swri-console-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-dbw-interface: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-geometry-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-image-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-math-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-opencv-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-prefix-tools: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-roscpp: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-route-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-serial-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-system-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-swri-transform-util: 3.3.0-1 -> 3.3.1-1
- ros-foxy-xacro: 2.0.2-1 -> 2.0.3-1
Removed Packages [0]:
- Aaron Blasdel
- Adam Allevato
- Alejandro Hernandez
- Apex.AI, Inc.
- Brian Wilcox
- Carl Delsey
- Carlos Orduno
- Chris Lalancette
- Daniel Stonier
- David V. Lu!!
- Dirk Thomas
- Eclipse Foundation, Inc.
- Evan Flynn
- Josh Whitley
- Justin Carpentier
- Louise Poubel
- Martins Mozeiko
- Mathias Lüdtke
- Michael Jeronimo
- Mohammad Haghighipanah
- P. J. Reed
- ROS Tooling Working Group
- Robert Haschke
- Steve Macenski
- Ubuntu Robotics
- Vladimir Ermakov
- William Woodall
- daf
- lkumarbe
