We’re happy to announce new packages for Foxy Fitzroy!
Package Updates for foxy
Added Packages [10]:
- ros-foxy-aws-robomaker-small-warehouse-world: 1.0.4-1
- ros-foxy-microstrain-inertial-driver: 2.0.6-1
- ros-foxy-microstrain-inertial-examples: 2.0.6-1
- ros-foxy-microstrain-inertial-msgs: 2.0.6-1
- ros-foxy-rosapi-msgs: 1.1.0-1
- ros-foxy-rosbridge-test-msgs: 1.1.0-1
- ros-foxy-velodyne-description: 2.0.1-1
- ros-foxy-velodyne-gazebo-plugins: 2.0.1-1
- ros-foxy-velodyne-simulator: 2.0.1-1
- ros-foxy-warehouse-ros-sqlite: 1.0.2-1
Updated Packages [40]:
- ros-foxy-controller-interface: 0.8.0-1 → 0.8.1-1
- ros-foxy-controller-manager: 0.8.0-1 → 0.8.1-1
- ros-foxy-controller-manager-msgs: 0.8.0-1 → 0.8.1-1
- ros-foxy-diff-drive-controller: 0.5.0-1 → 0.5.1-1
- ros-foxy-effort-controllers: 0.5.0-1 → 0.5.1-1
- ros-foxy-fastrtps: 2.0.2-2 → 2.1.1-1
- ros-foxy-force-torque-sensor-broadcaster: 0.5.0-1 → 0.5.1-1
- ros-foxy-forward-command-controller: 0.5.0-1 → 0.5.1-1
- ros-foxy-gazebo-ros2-control: 0.0.3-1 → 0.0.5-1
- ros-foxy-gazebo-ros2-control-demos: 0.0.3-1 → 0.0.5-1
- ros-foxy-gripper-controllers: 0.5.0-1 → 0.5.1-1
- ros-foxy-hardware-interface: 0.8.0-1 → 0.8.1-1
- ros-foxy-imu-sensor-broadcaster: 0.5.0-1 → 0.5.1-1
- ros-foxy-joint-state-broadcaster: 0.5.0-1 → 0.5.1-1
- ros-foxy-joint-state-controller: 0.5.0-1 → 0.5.1-1
- ros-foxy-joint-trajectory-controller: 0.5.0-1 → 0.5.1-1
- ros-foxy-plotjuggler: 3.3.1-2 → 3.3.2-1
- ros-foxy-plotjuggler-ros: 1.6.1-1 → 1.6.2-1
- ros-foxy-pmb2-2dnav-gazebo: 3.0.1-1 → 3.0.2-1
- ros-foxy-pmb2-bringup: 4.0.2-1 → 4.0.4-1
- ros-foxy-pmb2-controller-configuration: 4.0.2-1 → 4.0.4-1
- ros-foxy-pmb2-description: 4.0.2-1 → 4.0.4-1
- ros-foxy-pmb2-gazebo: 3.0.1-1 → 3.0.2-1
- ros-foxy-pmb2-robot: 4.0.2-1 → 4.0.4-1
- ros-foxy-pmb2-simulation: 3.0.1-1 → 3.0.2-1
- ros-foxy-position-controllers: 0.5.0-1 → 0.5.1-1
- ros-foxy-rmw-gurumdds-cpp: 1.0.10-1 → 1.0.12-1
- ros-foxy-rmw-gurumdds-shared-cpp: 1.0.10-1 → 1.0.12-1
- ros-foxy-ros2-control: 0.8.0-1 → 0.8.1-1
- ros-foxy-ros2-control-test-assets: 0.8.0-1 → 0.8.1-1
- ros-foxy-ros2-controllers: 0.5.0-1 → 0.5.1-1
- ros-foxy-ros2controlcli: 0.8.0-1 → 0.8.1-1
- ros-foxy-rosapi: 1.0.7-1 → 1.1.0-1
- ros-foxy-rosbridge-library: 1.0.7-1 → 1.1.0-1
- ros-foxy-rosbridge-msgs: 1.0.7-1 → 1.1.0-1
- ros-foxy-rosbridge-server: 1.0.7-1 → 1.1.0-1
- ros-foxy-rosbridge-suite: 1.0.7-1 → 1.1.0-1
- ros-foxy-simple-launch: 1.1.0-1 → 1.2.0-1
- ros-foxy-transmission-interface: 0.8.0-1 → 0.8.1-1
- ros-foxy-velocity-controllers: 0.5.0-1 → 0.5.1-1
Removed Packages [0]:
- AWS RoboMaker
- Alejandro Hernandez
- Bence Magyar
- Davide Faconti
- Hans-Joachim Krauch
- Jihoon Lee
- Karsten Knese
- Kevin Hallenbeck
- MoveIt Release Team
- Olivier Kermorgant
- PAL Robotics
- Rob Fisher
- Steven! Ragnarök
- Victor Lopez
- Youngjin Yun
- karsten
