Package Updates for Humble
Added Packages [44]:
- ros-humble-create-bringup: 3.1.0-1
- ros-humble-create-description: 3.1.0-1
- ros-humble-create-driver: 3.1.0-1
- ros-humble-create-driver-dbgsym: 3.1.0-1
- ros-humble-create-msgs: 3.1.0-1
- ros-humble-create-msgs-dbgsym: 3.1.0-1
- ros-humble-create-robot: 3.1.0-1
- ros-humble-delphi-esr-msgs: 4.0.0-1
- ros-humble-delphi-esr-msgs-dbgsym: 4.0.0-1
- ros-humble-delphi-mrr-msgs: 4.0.0-1
- ros-humble-delphi-mrr-msgs-dbgsym: 4.0.0-1
- ros-humble-delphi-srr-msgs: 4.0.0-1
- ros-humble-delphi-srr-msgs-dbgsym: 4.0.0-1
- ros-humble-derived-object-msgs: 4.0.0-1
- ros-humble-derived-object-msgs-dbgsym: 4.0.0-1
- ros-humble-heaphook: 0.1.0-1
- ros-humble-heaphook-dbgsym: 0.1.0-1
- ros-humble-ibeo-msgs: 4.0.0-1
- ros-humble-ibeo-msgs-dbgsym: 4.0.0-1
- ros-humble-kartech-linear-actuator-msgs: 4.0.0-1
- ros-humble-kartech-linear-actuator-msgs-dbgsym: 4.0.0-1
- ros-humble-lanelet2-matching: 1.2.1-1
- ros-humble-lanelet2-matching-dbgsym: 1.2.1-1
- ros-humble-libcreate: 3.1.0-1
- ros-humble-libcreate-dbgsym: 3.1.0-1
- ros-humble-mobileye-560-660-msgs: 4.0.0-1
- ros-humble-mobileye-560-660-msgs-dbgsym: 4.0.0-1
- ros-humble-neobotix-usboard-msgs: 4.0.0-1
- ros-humble-neobotix-usboard-msgs-dbgsym: 4.0.0-1
- ros-humble-ntrip-client-node: 0.4.4-1
- ros-humble-ntrip-client-node-dbgsym: 0.4.4-1
- ros-humble-turtlebot4-ignition-bringup: 1.0.0-1
- ros-humble-turtlebot4-ignition-gui-plugins: 1.0.0-1
- ros-humble-turtlebot4-ignition-gui-plugins-dbgsym: 1.0.0-1
- ros-humble-turtlebot4-ignition-toolbox: 1.0.0-1
- ros-humble-turtlebot4-ignition-toolbox-dbgsym: 1.0.0-1
- ros-humble-turtlebot4-simulator: 1.0.0-1
- ros-humble-ublox-nav-sat-fix-hp-node: 0.4.4-1
- ros-humble-ublox-nav-sat-fix-hp-node-dbgsym: 0.4.4-1
- ros-humble-vrpn-mocap: 1.0.4-1
- ros-humble-vrpn-mocap-dbgsym: 1.0.4-1
- ros-humble-wireless-msgs: 1.0.1-2
- ros-humble-wireless-msgs-dbgsym: 1.0.1-2
- ros-humble-wireless-watcher: 1.0.1-2
Updated Packages [243]:
- ros-humble-admittance-controller: 2.17.3-1 β 2.20.0-1
- ros-humble-admittance-controller-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-aruco-opencv: 2.1.0-1 β 2.1.1-1
- ros-humble-aruco-opencv-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-humble-aruco-opencv-msgs: 2.1.0-1 β 2.1.1-1
- ros-humble-aruco-opencv-msgs-dbgsym: 2.1.0-1 β 2.1.1-1
- ros-humble-as2-cli: 1.0.0-1 β 1.0.0-2
- ros-humble-as2-gazebo-classic-assets: 1.0.0-1 β 1.0.0-2
- ros-humble-control-msgs: 4.1.1-1 β 4.4.0-1
- ros-humble-control-msgs-dbgsym: 4.1.1-1 β 4.4.0-1
- ros-humble-control-toolbox: 3.0.0-1 β 3.1.0-1
- ros-humble-control-toolbox-dbgsym: 3.0.0-1 β 3.1.0-1
- ros-humble-controller-interface: 2.25.2-1 β 2.26.0-1
- ros-humble-controller-interface-dbgsym: 2.25.2-1 β 2.26.0-1
- ros-humble-controller-manager: 2.25.2-1 β 2.26.0-1
- ros-humble-controller-manager-dbgsym: 2.25.2-1 β 2.26.0-1
- ros-humble-controller-manager-msgs: 2.25.2-1 β 2.26.0-1
- ros-humble-controller-manager-msgs-dbgsym: 2.25.2-1 β 2.26.0-1
- ros-humble-depthai-bridge: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-bridge-dbgsym: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-descriptions: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-examples: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-examples-dbgsym: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-filters: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-filters-dbgsym: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-ros: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-ros-driver: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-ros-driver-dbgsym: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-ros-msgs: 2.7.1-1 β 2.7.2-1
- ros-humble-depthai-ros-msgs-dbgsym: 2.7.1-1 β 2.7.2-1
- ros-humble-diff-drive-controller: 2.17.3-1 β 2.20.0-1
- ros-humble-diff-drive-controller-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-effort-controllers: 2.17.3-1 β 2.20.0-1
- ros-humble-effort-controllers-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-force-torque-sensor-broadcaster: 2.17.3-1 β 2.20.0-1
- ros-humble-force-torque-sensor-broadcaster-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-forward-command-controller: 2.17.3-1 β 2.20.0-1
- ros-humble-forward-command-controller-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-foxglove-bridge: 0.5.3-1 β 0.6.2-1
- ros-humble-foxglove-bridge-dbgsym: 0.5.3-1 β 0.6.2-1
- ros-humble-gazebo-ros2-control: 0.4.2-1 β 0.4.3-1
- ros-humble-gazebo-ros2-control-dbgsym: 0.4.2-1 β 0.4.3-1
- ros-humble-gazebo-ros2-control-demos: 0.4.2-1 β 0.4.3-1
- ros-humble-gazebo-ros2-control-demos-dbgsym: 0.4.2-1 β 0.4.3-1
- ros-humble-gripper-controllers: 2.17.3-1 β 2.20.0-1
- ros-humble-gripper-controllers-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-hardware-interface: 2.25.2-1 β 2.26.0-1
- ros-humble-hardware-interface-dbgsym: 2.25.2-1 β 2.26.0-1
- ros-humble-ign-ros2-control: 0.4.4-1 β 0.7.0-1
- ros-humble-ign-ros2-control-dbgsym: 0.4.4-1 β 0.7.0-1
- ros-humble-ign-ros2-control-demos: 0.4.4-1 β 0.7.0-1
- ros-humble-ign-ros2-control-demos-dbgsym: 0.4.4-1 β 0.7.0-1
- ros-humble-imu-sensor-broadcaster: 2.17.3-1 β 2.20.0-1
- ros-humble-imu-sensor-broadcaster-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-irobot-create-common-bringup: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-control: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-description: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-gazebo-bringup: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-gazebo-plugins: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-gazebo-plugins-dbgsym: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-gazebo-sim: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-ignition-bringup: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-ignition-plugins: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-ignition-plugins-dbgsym: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-ignition-sim: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-ignition-toolbox: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-ignition-toolbox-dbgsym: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-nodes: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-nodes-dbgsym: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-toolbox: 2.0.0-1 β 2.1.0-1
- ros-humble-irobot-create-toolbox-dbgsym: 2.0.0-1 β 2.1.0-1
- ros-humble-joint-limits: 2.25.2-1 β 2.26.0-1
- ros-humble-joint-limits-dbgsym: 2.25.2-1 β 2.26.0-1
- ros-humble-joint-state-broadcaster: 2.17.3-1 β 2.20.0-1
- ros-humble-joint-state-broadcaster-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-joint-trajectory-controller: 2.17.3-1 β 2.20.0-1
- ros-humble-joint-trajectory-controller-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-lanelet2: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-core: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-core-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-examples: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-examples-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-io: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-io-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-maps: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-projection: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-projection-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-python: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-python-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-routing: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-routing-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-traffic-rules: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-traffic-rules-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-validation: 1.1.1-4 β 1.2.1-1
- ros-humble-lanelet2-validation-dbgsym: 1.1.1-4 β 1.2.1-1
- ros-humble-libcamera: 0.0.4-6 β 0.0.5-1
- ros-humble-libmavconn: 2.4.0-1 β 2.5.0-1
- ros-humble-libmavconn-dbgsym: 2.4.0-1 β 2.5.0-1
- ros-humble-marti-can-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-can-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-common-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-common-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-dbw-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-dbw-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-introspection-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-introspection-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-nav-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-nav-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-perception-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-perception-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-sensor-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-sensor-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-status-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-status-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-visualization-msgs: 1.4.0-2 β 1.4.1-1
- ros-humble-marti-visualization-msgs-dbgsym: 1.4.0-2 β 1.4.1-1
- ros-humble-mavros: 2.4.0-1 β 2.5.0-1
- ros-humble-mavros-dbgsym: 2.4.0-1 β 2.5.0-1
- ros-humble-mavros-extras: 2.4.0-1 β 2.5.0-1
- ros-humble-mavros-extras-dbgsym: 2.4.0-1 β 2.5.0-1
- ros-humble-mavros-msgs: 2.4.0-1 β 2.5.0-1
- ros-humble-mavros-msgs-dbgsym: 2.4.0-1 β 2.5.0-1
- ros-humble-mrpt-msgs: 0.4.4-1 β 0.4.5-1
- ros-humble-mrpt-msgs-dbgsym: 0.4.4-1 β 0.4.5-1
- ros-humble-nao-lola: 0.1.0-1 β 0.1.2-1
- ros-humble-nao-lola-dbgsym: 0.1.0-1 β 0.1.2-1
- ros-humble-openni2-camera: 2.0.1-1 β 2.0.2-1
- ros-humble-openni2-camera-dbgsym: 2.0.1-1 β 2.0.2-1
- ros-humble-pal-gazebo-worlds: 3.0.3-1 β 4.0.0-1
- ros-humble-pal-navigation-cfg: 3.0.1-1 β 3.0.4-1
- ros-humble-pal-navigation-cfg-bringup: 3.0.1-1 β 3.0.4-1
- ros-humble-pal-navigation-cfg-params: 3.0.1-1 β 3.0.4-1
- ros-humble-play-motion2: 0.0.7-1 β 0.0.8-1
- ros-humble-play-motion2-dbgsym: 0.0.7-1 β 0.0.8-1
- ros-humble-play-motion2-msgs: 0.0.7-1 β 0.0.8-1
- ros-humble-play-motion2-msgs-dbgsym: 0.0.7-1 β 0.0.8-1
- ros-humble-plotjuggler: 3.5.1-1 β 3.7.1-1
- ros-humble-plotjuggler-dbgsym: 3.5.1-1 β 3.7.1-1
- ros-humble-pmb2-2dnav: 4.0.3-1 β 4.0.4-1
- ros-humble-pmb2-bringup: 5.0.3-1 β 5.0.4-1
- ros-humble-pmb2-controller-configuration: 5.0.3-1 β 5.0.4-1
- ros-humble-pmb2-description: 5.0.3-1 β 5.0.4-1
- ros-humble-pmb2-gazebo: 4.0.2-1 β 4.0.3-1
- ros-humble-pmb2-laser-sensors: 4.0.3-1 β 4.0.4-1
- ros-humble-pmb2-maps: 4.0.3-1 β 4.0.4-1
- ros-humble-pmb2-navigation: 4.0.3-1 β 4.0.4-1
- ros-humble-pmb2-robot: 5.0.3-1 β 5.0.4-1
- ros-humble-pmb2-simulation: 4.0.2-1 β 4.0.3-1
- ros-humble-position-controllers: 2.17.3-1 β 2.20.0-1
- ros-humble-position-controllers-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-proxsuite: 0.3.6-1 β 0.3.6-2
- ros-humble-rig-reconfigure: 1.0.0-1 β 1.1.0-1
- ros-humble-rig-reconfigure-dbgsym: 1.0.0-1 β 1.1.0-1
- ros-humble-rmf-fleet-adapter: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-fleet-adapter-dbgsym: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-fleet-adapter-python: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-task-ros2: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-task-ros2-dbgsym: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-traffic-ros2: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-traffic-ros2-dbgsym: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-websocket: 2.1.2-1 β 2.1.5-1
- ros-humble-rmf-websocket-dbgsym: 2.1.2-1 β 2.1.5-1
- ros-humble-robot-localization: 3.5.0-1 β 3.5.1-2
- ros-humble-robot-localization-dbgsym: 3.5.0-1 β 3.5.1-2
- ros-humble-ros-gz: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-bridge: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-bridge-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-image: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-image-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-interfaces: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-interfaces-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-sim: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-sim-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-gz-sim-demos: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-bridge: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-bridge-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-gazebo: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-gazebo-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-gazebo-demos: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-image: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-image-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-interfaces: 0.244.9-1 β 0.244.11-1
- ros-humble-ros-ign-interfaces-dbgsym: 0.244.9-1 β 0.244.11-1
- ros-humble-ros2-control: 2.25.2-1 β 2.26.0-1
- ros-humble-ros2-control-test-assets: 2.25.2-1 β 2.26.0-1
- ros-humble-ros2-controllers: 2.17.3-1 β 2.20.0-1
- ros-humble-ros2-controllers-test-nodes: 2.17.3-1 β 2.20.0-1
- ros-humble-ros2controlcli: 2.25.2-1 β 2.26.0-1
- ros-humble-rqt-controller-manager: 2.25.2-1 β 2.26.0-1
- ros-humble-rqt-joint-trajectory-controller: 2.17.3-1 β 2.20.0-1
- ros-humble-rviz-2d-overlay-msgs: 1.2.1-1 β 1.3.0-1
- ros-humble-rviz-2d-overlay-msgs-dbgsym: 1.2.1-1 β 1.3.0-1
- ros-humble-rviz-2d-overlay-plugins: 1.2.1-1 β 1.3.0-1
- ros-humble-rviz-2d-overlay-plugins-dbgsym: 1.2.1-1 β 1.3.0-1
- ros-humble-simple-launch: 1.7.0-1 β 1.7.1-1
- ros-humble-tiago-bringup: 4.0.6-1 β 4.0.7-1
- ros-humble-tiago-controller-configuration: 4.0.6-1 β 4.0.7-1
- ros-humble-tiago-description: 4.0.6-1 β 4.0.7-1
- ros-humble-tiago-robot: 4.0.6-1 β 4.0.7-1
- ros-humble-transmission-interface: 2.25.2-1 β 2.26.0-1
- ros-humble-transmission-interface-dbgsym: 2.25.2-1 β 2.26.0-1
- ros-humble-tricycle-controller: 2.17.3-1 β 2.20.0-1
- ros-humble-tricycle-controller-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-turtlebot4-cpp-tutorials: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-cpp-tutorials-dbgsym: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-description: 1.0.1-1 β 1.0.2-1
- ros-humble-turtlebot4-msgs: 1.0.1-1 β 1.0.2-1
- ros-humble-turtlebot4-msgs-dbgsym: 1.0.1-1 β 1.0.2-1
- ros-humble-turtlebot4-navigation: 1.0.1-1 β 1.0.2-1
- ros-humble-turtlebot4-node: 1.0.1-1 β 1.0.2-1
- ros-humble-turtlebot4-node-dbgsym: 1.0.1-1 β 1.0.2-1
- ros-humble-turtlebot4-python-tutorials: 1.0.0-1 β 1.0.1-1
- ros-humble-turtlebot4-tutorials: 1.0.0-1 β 1.0.1-1
- ros-humble-tuw-geometry: 0.0.7-1 β 0.0.9-1
- ros-humble-tuw-geometry-dbgsym: 0.0.7-1 β 0.0.9-1
- ros-humble-ublox-dgnss: 0.3.5-4 β 0.4.4-1
- ros-humble-ublox-dgnss-node: 0.3.5-4 β 0.4.4-1
- ros-humble-ublox-dgnss-node-dbgsym: 0.3.5-4 β 0.4.4-1
- ros-humble-ublox-ubx-interfaces: 0.3.5-4 β 0.4.4-1
- ros-humble-ublox-ubx-interfaces-dbgsym: 0.3.5-4 β 0.4.4-1
- ros-humble-ublox-ubx-msgs: 0.3.5-4 β 0.4.4-1
- ros-humble-ublox-ubx-msgs-dbgsym: 0.3.5-4 β 0.4.4-1
- ros-humble-urdfdom-py: 1.2.0-2 β 1.2.1-1
- ros-humble-v4l2-camera: 0.6.0-1 β 0.6.2-1
- ros-humble-v4l2-camera-dbgsym: 0.6.0-1 β 0.6.2-1
- ros-humble-velocity-controllers: 2.17.3-1 β 2.20.0-1
- ros-humble-velocity-controllers-dbgsym: 2.17.3-1 β 2.20.0-1
- ros-humble-webots-ros2: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-control: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-control-dbgsym: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-driver: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-driver-dbgsym: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-epuck: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-importer: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-mavic: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-msgs: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-msgs-dbgsym: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-tesla: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-tests: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-tiago: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-turtlebot: 2023.0.3-1 β 2023.0.4-1
- ros-humble-webots-ros2-universal-robot: 2023.0.3-1 β 2023.0.4-1
Removed Packages [1]:
- ros-humble-libcamera-dbgsym
- Adam Serafin
- Alejandro HernΓ‘ndez
- Alvin Sun
- Antonio Brandi
- AutonomouStuff Software Team
- Bence Magyar
- Brandon Ong
- Chris Lalancette
- Christian Rauch
- Computer Vision And Aerial Robotics Group (UPM)
- Cyberbotics
- Davide Faconti
- Denis Ε togl
- Ekumen
- Fabian Immel
- Fictionlab
- Geoff Sokoll
- Grey
- Jacob Perron
- Jan-Hendrik Pauls
- John Hurliman
- Jordan Palacios
- Jordi Pages
- Jose-Luis Blanco-Claraco
- Justin Carpentier
- Louise Poubel
- Markus Bader
- Michael Ferguson
- Miguel Fernandez-Cortizas
- Nick Hortovanyi
- Noel Jimenez
- Olivier Kermorgant
- Roni Kreinin
- Sachin Guruswamy
- Sander G. van Dijk
- Southwest Research Institute
- Team Spatzenhirn
- Tom Moore
- Vladimir Ermakov
- Yadunund
- ijnek
- methylDragon
- rkreinin
- sachin
- sykwer
