New packages for Humble Hawksbill 2025-01-21
Package Updates for Humble
Added Packages [24]:
Updated Packages [282]:
  • ros-humble-ackermann-steering-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-ackermann-steering-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-admittance-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-admittance-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-autoware-internal-msgs: 1.1.0-1 → 1.3.0-1
  • ros-humble-autoware-internal-msgs-dbgsym: 1.1.0-1 → 1.3.0-1
  • ros-humble-bicycle-steering-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-bicycle-steering-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-camera-ros: 0.2.1-1 → 0.3.0-1
  • ros-humble-camera-ros-dbgsym: 0.2.1-1 → 0.3.0-1
  • ros-humble-chomp-motion-planner: 2.5.6-1 → 2.5.7-1
  • ros-humble-chomp-motion-planner-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-clearpath-common: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-config: 1.0.0-1 → 1.1.0-1
  • ros-humble-clearpath-control: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-customization: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-description: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-generator-common: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-generator-common-dbgsym: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-manipulators: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-manipulators-description: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-mounts-description: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-platform-description: 1.0.0-1 → 1.1.1-1
  • ros-humble-clearpath-sensors-description: 1.0.0-1 → 1.1.1-1
  • ros-humble-control-toolbox: 3.4.0-1 → 3.6.0-1
  • ros-humble-control-toolbox-dbgsym: 3.4.0-1 → 3.6.0-1
  • ros-humble-controller-interface: 2.46.0-1 → 2.47.0-1
  • ros-humble-controller-interface-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-controller-manager: 2.46.0-1 → 2.47.0-1
  • ros-humble-controller-manager-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-controller-manager-msgs: 2.46.0-1 → 2.47.0-1
  • ros-humble-controller-manager-msgs-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-depthai: 2.28.0-1 → 2.29.0-1
  • ros-humble-depthai-bridge: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-bridge-dbgsym: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-dbgsym: 2.28.0-1 → 2.29.0-1
  • ros-humble-depthai-descriptions: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-examples: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-examples-dbgsym: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-filters: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-filters-dbgsym: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-ros: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-ros-driver: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-ros-driver-dbgsym: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-ros-msgs: 2.10.4-1 → 2.10.5-1
  • ros-humble-depthai-ros-msgs-dbgsym: 2.10.4-1 → 2.10.5-1
  • ros-humble-diff-drive-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-diff-drive-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-effort-controllers: 2.39.0-1 → 2.41.0-1
  • ros-humble-effort-controllers-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-examples-tf2-py: 0.25.9-1 → 0.25.11-1
  • ros-humble-force-torque-sensor-broadcaster: 2.39.0-1 → 2.41.0-1
  • ros-humble-force-torque-sensor-broadcaster-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-forward-command-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-forward-command-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-generate-parameter-library: 0.3.9-1 → 0.4.0-1
  • ros-humble-generate-parameter-library-example: 0.3.9-1 → 0.4.0-1
  • ros-humble-generate-parameter-library-example-dbgsym: 0.3.9-1 → 0.4.0-1
  • ros-humble-generate-parameter-library-py: 0.3.9-1 → 0.4.0-1
  • ros-humble-generate-parameter-module-example: 0.3.9-1 → 0.4.0-1
  • ros-humble-geometry2: 0.25.9-1 → 0.25.11-1
  • ros-humble-gripper-controllers: 2.39.0-1 → 2.41.0-1
  • ros-humble-gripper-controllers-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-hardware-interface: 2.46.0-1 → 2.47.0-1
  • ros-humble-hardware-interface-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-hardware-interface-testing: 2.46.0-1 → 2.47.0-1
  • ros-humble-hardware-interface-testing-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-imu-sensor-broadcaster: 2.39.0-1 → 2.41.0-1
  • ros-humble-imu-sensor-broadcaster-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-joint-limits: 2.46.0-1 → 2.47.0-1
  • ros-humble-joint-limits-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-joint-state-broadcaster: 2.39.0-1 → 2.41.0-1
  • ros-humble-joint-state-broadcaster-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-joint-trajectory-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-joint-trajectory-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-kitti-metrics-eval: 1.3.0-1 → 1.5.1-1
  • ros-humble-kitti-metrics-eval-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-bridge-ros2: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-bridge-ros2-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-demos: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-imu-preintegration: 1.3.0-1 → 1.6.1-1
  • ros-humble-mola-imu-preintegration-dbgsym: 1.3.0-1 → 1.6.1-1
  • ros-humble-mola-input-euroc-dataset: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-euroc-dataset-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-kitti-dataset: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-kitti-dataset-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-kitti360-dataset: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-kitti360-dataset-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-mulran-dataset: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-mulran-dataset-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-paris-luco-dataset: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-paris-luco-dataset-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-rawlog: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-rawlog-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-rosbag2: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-input-rosbag2-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-kernel: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-kernel-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-launcher: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-launcher-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-lidar-odometry: 0.3.3-1 → 0.5.4-1
  • ros-humble-mola-lidar-odometry-dbgsym: 0.3.3-1 → 0.5.4-1
  • ros-humble-mola-metric-maps: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-metric-maps-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-msgs: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-msgs-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-pose-list: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-pose-list-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-relocalization: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-relocalization-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-test-datasets: 0.3.4-1 → 0.4.0-1
  • ros-humble-mola-traj-tools: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-traj-tools-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-viz: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-viz-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-yaml: 1.3.0-1 → 1.5.1-1
  • ros-humble-mola-yaml-dbgsym: 1.3.0-1 → 1.5.1-1
  • ros-humble-moveit: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-chomp-optimizer-adapter: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-chomp-optimizer-adapter-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-common: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-configs-utils: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-core: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-core-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-hybrid-planning: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-hybrid-planning-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-kinematics: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-kinematics-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-planners: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-planners-chomp: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-planners-chomp-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-planners-ompl: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-planners-ompl-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-plugins: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-resources-prbt-ikfast-manipulator-plugin: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-resources-prbt-ikfast-manipulator-plugin-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-resources-prbt-moveit-config: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-resources-prbt-pg70-support: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-resources-prbt-support: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-benchmarks: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-benchmarks-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-control-interface: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-control-interface-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-move-group: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-move-group-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-occupancy-map-monitor: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-occupancy-map-monitor-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-perception: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-perception-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-planning: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-planning-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-planning-interface: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-planning-interface-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-robot-interaction: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-robot-interaction-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-visualization: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-visualization-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-warehouse: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-ros-warehouse-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-runtime: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-servo: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-servo-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-app-plugins: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-app-plugins-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-assistant: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-assistant-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-controllers: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-controllers-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-core-plugins: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-core-plugins-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-framework: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-framework-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-srdf-plugins: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-setup-srdf-plugins-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-simple-controller-manager: 2.5.6-1 → 2.5.7-1
  • ros-humble-moveit-simple-controller-manager-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-mp2p-icp: 1.6.3-1 → 1.6.4-1
  • ros-humble-mp2p-icp-dbgsym: 1.6.3-1 → 1.6.4-1
  • ros-humble-mvsim: 0.12.0-1 → 0.13.0-1
  • ros-humble-mvsim-dbgsym: 0.12.0-1 → 0.13.0-1
  • ros-humble-ntrip-client: 1.3.0-1 → 1.4.0-1
  • ros-humble-parameter-traits: 0.3.9-1 → 0.4.0-1
  • ros-humble-pid-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-pid-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-pilz-industrial-motion-planner: 2.5.6-1 → 2.5.7-1
  • ros-humble-pilz-industrial-motion-planner-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-pilz-industrial-motion-planner-testutils: 2.5.6-1 → 2.5.7-1
  • ros-humble-pilz-industrial-motion-planner-testutils-dbgsym: 2.5.6-1 → 2.5.7-1
  • ros-humble-pose-broadcaster: 2.39.0-1 → 2.41.0-1
  • ros-humble-pose-broadcaster-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-position-controllers: 2.39.0-1 → 2.41.0-1
  • ros-humble-position-controllers-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-py-trees: 2.2.3-1 → 2.3.0-1
  • ros-humble-py-trees-js: 0.6.4-1 → 0.6.6-1
  • ros-humble-py-trees-ros: 2.2.2-3 → 2.3.0-1
  • ros-humble-py-trees-ros-interfaces: 2.1.0-1 → 2.1.1-1
  • ros-humble-py-trees-ros-interfaces-dbgsym: 2.1.0-1 → 2.1.1-1
  • ros-humble-qml-ros2-plugin: 1.0.1-1 → 1.0.1-2
  • ros-humble-qml-ros2-plugin-dbgsym: 1.0.1-1 → 1.0.1-2
  • ros-humble-range-sensor-broadcaster: 2.39.0-1 → 2.41.0-1
  • ros-humble-range-sensor-broadcaster-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-ros2-control: 2.46.0-1 → 2.47.0-1
  • ros-humble-ros2-control-test-assets: 2.46.0-1 → 2.47.0-1
  • ros-humble-ros2-controllers: 2.39.0-1 → 2.41.0-1
  • ros-humble-ros2-controllers-test-nodes: 2.39.0-1 → 2.41.0-1
  • ros-humble-ros2controlcli: 2.46.0-1 → 2.47.0-1
  • ros-humble-rqt-controller-manager: 2.46.0-1 → 2.47.0-1
  • ros-humble-rqt-joint-trajectory-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-rviz-assimp-vendor: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-common: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-common-dbgsym: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-default-plugins: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-default-plugins-dbgsym: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-ogre-vendor: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-ogre-vendor-dbgsym: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-rendering: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-rendering-dbgsym: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-rendering-tests: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz-visual-testing-framework: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz2: 11.2.14-1 → 11.2.16-1
  • ros-humble-rviz2-dbgsym: 11.2.14-1 → 11.2.16-1
  • ros-humble-steering-controllers-library: 2.39.0-1 → 2.41.0-1
  • ros-humble-steering-controllers-library-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-tensorrt-cmake-module: 0.0.3-1 → 0.0.4-1
  • ros-humble-tf2: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-bullet: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-dbgsym: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-eigen: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-eigen-kdl: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-eigen-kdl-dbgsym: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-geometry-msgs: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-kdl: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-msgs: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-msgs-dbgsym: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-py: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-py-dbgsym: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-ros: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-ros-dbgsym: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-ros-py: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-sensor-msgs: 0.25.9-1 → 0.25.11-1
  • ros-humble-tf2-tools: 0.25.9-1 → 0.25.11-1
  • ros-humble-transmission-interface: 2.46.0-1 → 2.47.0-1
  • ros-humble-transmission-interface-dbgsym: 2.46.0-1 → 2.47.0-1
  • ros-humble-tricycle-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-tricycle-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-tricycle-steering-controller: 2.39.0-1 → 2.41.0-1
  • ros-humble-tricycle-steering-controller-dbgsym: 2.39.0-1 → 2.41.0-1
  • ros-humble-turtlebot4-setup: 1.0.4-1 → 1.0.5-1
  • ros-humble-tuw-airskin-msgs: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-airskin-msgs-dbgsym: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-geo-msgs: 0.2.3-1 → 0.2.5-1
  • ros-humble-tuw-geo-msgs-dbgsym: 0.2.3-1 → 0.2.5-1
  • ros-humble-tuw-geometry-msgs: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-geometry-msgs-dbgsym: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-graph-msgs: 0.2.3-1 → 0.2.5-1
  • ros-humble-tuw-graph-msgs-dbgsym: 0.2.3-1 → 0.2.5-1
  • ros-humble-tuw-msgs: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-multi-robot-msgs: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-multi-robot-msgs-dbgsym: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-nav-msgs: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-nav-msgs-dbgsym: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-object-map-msgs: 0.2.3-1 → 0.2.5-1
  • ros-humble-tuw-object-map-msgs-dbgsym: 0.2.3-1 → 0.2.5-1
  • ros-humble-tuw-object-msgs: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-object-msgs-dbgsym: 0.2.1-1 → 0.2.5-1
  • ros-humble-tuw-std-msgs: 0.2.4-1 → 0.2.5-1
  • ros-humble-tuw-std-msgs-dbgsym: 0.2.4-1 → 0.2.5-1
  • ros-humble-ur: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-bringup: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-calibration: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-calibration-dbgsym: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-controllers: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-controllers-dbgsym: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-dashboard-msgs: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-dashboard-msgs-dbgsym: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-moveit-config: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-robot-driver: 2.2.16-5 → 2.5.1-1
  • ros-humble-ur-robot-driver-dbgsym: 2.2.16-5 → 2.5.1-1
  • ros-humble-velocity-controllers: 2.39.0-1 → 2.41.0-1
  • ros-humble-velocity-controllers-dbgsym: 2.39.0-1 → 2.41.0-1
Removed Packages [4]:
  • Adam Serafin
  • Alexander Gutenkunst
  • Automatika Robotics
  • Bence Magyar
  • Benjamin Binder
  • Berkay Karaman
  • Blake Anderson
  • Chittaranjan Srinivas Swaminathan
  • Chris Lalancette
  • Christian Henkel
  • Christian Rauch
  • Daisuke Nishimatsu
  • Daniel Stonier
  • David V. Lu!!
  • Felix Exner
  • George Todoran
  • Henning Kayser
  • Jacob Perron
  • Jafar Uruc
  • Jose Luis Blanco-Claraco
  • Jose-Luis Blanco-Claraco
  • Joseph Mirabel
  • Luis Camero
  • M. Fatih Cırıt
  • Markus Bader
  • Michael Görner
  • MoveIt Release Team
  • Paul Gesel
  • Raghavender Sahdev
  • Rob Fisher
  • Ryohsuke Mitsudome
  • Stefan Fabian
  • Tyler Weaver
  • Yadunund
  • paul
  • rkreinin
