Weβre happy to announce 49 new packages and 123 updates are now available in ROS 2 Iron Irwini . This sync was tagged as iron/2024-04-05
Package Updates for iron
Added Packages [49]:
- ros-iron-kitti-metrics-eval: 1.0.1-1
- ros-iron-kitti-metrics-eval-dbgsym: 1.0.1-1
- ros-iron-microstrain-inertial-description: 4.1.0-1
- ros-iron-mola: 1.0.1-1
- ros-iron-mola-bridge-ros2: 1.0.1-1
- ros-iron-mola-bridge-ros2-dbgsym: 1.0.1-1
- ros-iron-mola-demos: 1.0.1-1
- ros-iron-mola-imu-preintegration: 1.0.1-1
- ros-iron-mola-imu-preintegration-dbgsym: 1.0.1-1
- ros-iron-mola-input-euroc-dataset: 1.0.1-1
- ros-iron-mola-input-euroc-dataset-dbgsym: 1.0.1-1
- ros-iron-mola-input-kitti-dataset: 1.0.1-1
- ros-iron-mola-input-kitti-dataset-dbgsym: 1.0.1-1
- ros-iron-mola-input-kitti360-dataset: 1.0.1-1
- ros-iron-mola-input-kitti360-dataset-dbgsym: 1.0.1-1
- ros-iron-mola-input-mulran-dataset: 1.0.1-1
- ros-iron-mola-input-mulran-dataset-dbgsym: 1.0.1-1
- ros-iron-mola-input-paris-luco-dataset: 1.0.1-1
- ros-iron-mola-input-paris-luco-dataset-dbgsym: 1.0.1-1
- ros-iron-mola-input-rawlog: 1.0.1-1
- ros-iron-mola-input-rawlog-dbgsym: 1.0.1-1
- ros-iron-mola-input-rosbag2: 1.0.1-1
- ros-iron-mola-input-rosbag2-dbgsym: 1.0.1-1
- ros-iron-mola-kernel: 1.0.1-1
- ros-iron-mola-kernel-dbgsym: 1.0.1-1
- ros-iron-mola-launcher: 1.0.1-1
- ros-iron-mola-launcher-dbgsym: 1.0.1-1
- ros-iron-mola-metric-maps: 1.0.1-1
- ros-iron-mola-metric-maps-dbgsym: 1.0.1-1
- ros-iron-mola-navstate-fuse: 1.0.1-1
- ros-iron-mola-navstate-fuse-dbgsym: 1.0.1-1
- ros-iron-mola-pose-list: 1.0.1-1
- ros-iron-mola-pose-list-dbgsym: 1.0.1-1
- ros-iron-mola-traj-tools: 1.0.1-1
- ros-iron-mola-traj-tools-dbgsym: 1.0.1-1
- ros-iron-mola-viz: 1.0.1-1
- ros-iron-mola-viz-dbgsym: 1.0.1-1
- ros-iron-mola-yaml: 1.0.1-1
- ros-iron-mola-yaml-dbgsym: 1.0.1-1
- ros-iron-mrpt-generic-sensor: 0.1.0-1
- ros-iron-mrpt-generic-sensor-dbgsym: 0.1.0-1
- ros-iron-mrpt-sensor-bumblebee-stereo: 0.1.0-1
- ros-iron-mrpt-sensor-bumblebee-stereo-dbgsym: 0.1.0-1
- ros-iron-mrpt-sensor-gnns-nmea: 0.1.0-1
- ros-iron-mrpt-sensor-gnns-nmea-dbgsym: 0.1.0-1
- ros-iron-mrpt-sensorlib: 0.1.0-1
- ros-iron-mrpt-sensors: 0.1.0-1
- ros-iron-unitree-ros: 1.1.0-1
- ros-iron-unitree-ros-dbgsym: 1.1.0-1
Updated Packages [123]:
- ros-iron-aruco-opencv: 5.0.0-1 β 5.1.0-1
- ros-iron-aruco-opencv-dbgsym: 5.0.0-1 β 5.1.0-1
- ros-iron-aruco-opencv-msgs: 5.0.0-1 β 5.1.0-1
- ros-iron-aruco-opencv-msgs-dbgsym: 5.0.0-1 β 5.1.0-1
- ros-iron-camera-calibration: 4.0.0-1 β 4.0.1-1
- ros-iron-camera-calibration-parsers: 4.2.3-1 β 4.2.4-1
- ros-iron-camera-calibration-parsers-dbgsym: 4.2.3-1 β 4.2.4-1
- ros-iron-camera-info-manager: 4.2.3-1 β 4.2.4-1
- ros-iron-camera-info-manager-dbgsym: 4.2.3-1 β 4.2.4-1
- ros-iron-depth-image-proc: 4.0.0-1 β 4.0.1-1
- ros-iron-depth-image-proc-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-fields2cover: 1.2.1-2 β 1.2.1-3
- ros-iron-fields2cover-dbgsym: 1.2.1-2 β 1.2.1-3
- ros-iron-flir-camera-description: 2.2.14-1 β 2.2.15-1
- ros-iron-flir-camera-msgs: 2.2.14-1 β 2.2.15-1
- ros-iron-flir-camera-msgs-dbgsym: 2.2.14-1 β 2.2.15-1
- ros-iron-gazebo-ros2-control: 0.6.4-1 β 0.6.5-1
- ros-iron-gazebo-ros2-control-dbgsym: 0.6.4-1 β 0.6.5-1
- ros-iron-gazebo-ros2-control-demos: 0.6.4-1 β 0.6.5-1
- ros-iron-gazebo-ros2-control-demos-dbgsym: 0.6.4-1 β 0.6.5-1
- ros-iron-gz-ros2-control: 1.1.4-2 β 1.1.5-1
- ros-iron-gz-ros2-control-dbgsym: 1.1.4-2 β 1.1.5-1
- ros-iron-gz-ros2-control-demos: 1.1.4-2 β 1.1.5-1
- ros-iron-gz-ros2-control-demos-dbgsym: 1.1.4-2 β 1.1.5-1
- ros-iron-image-common: 4.2.3-1 β 4.2.4-1
- ros-iron-image-pipeline: 4.0.0-1 β 4.0.1-1
- ros-iron-image-proc: 4.0.0-1 β 4.0.1-1
- ros-iron-image-proc-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-image-publisher: 4.0.0-1 β 4.0.1-1
- ros-iron-image-publisher-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-image-rotate: 4.0.0-1 β 4.0.1-1
- ros-iron-image-rotate-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-image-transport: 4.2.3-1 β 4.2.4-1
- ros-iron-image-transport-dbgsym: 4.2.3-1 β 4.2.4-1
- ros-iron-image-view: 4.0.0-1 β 4.0.1-1
- ros-iron-image-view-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-microstrain-inertial-driver: 3.2.1-1 β 4.1.0-1
- ros-iron-microstrain-inertial-driver-dbgsym: 3.2.1-1 β 4.1.0-1
- ros-iron-microstrain-inertial-examples: 3.2.1-1 β 4.1.0-1
- ros-iron-microstrain-inertial-msgs: 3.2.1-1 β 4.1.0-1
- ros-iron-microstrain-inertial-msgs-dbgsym: 3.2.1-1 β 4.1.0-1
- ros-iron-microstrain-inertial-rqt: 3.2.1-1 β 4.1.0-1
- ros-iron-mola-test-datasets: 0.3.0-1 β 0.3.1-1
- ros-iron-mvsim: 0.9.1-1 β 0.9.2-1
- ros-iron-mvsim-dbgsym: 0.9.1-1 β 0.9.2-1
- ros-iron-ntrip-client-node: 0.5.2-1 β 0.5.3-1
- ros-iron-ntrip-client-node-dbgsym: 0.5.2-1 β 0.5.3-1
- ros-iron-point-cloud-transport: 2.0.4-1 β 2.0.5-1
- ros-iron-point-cloud-transport-dbgsym: 2.0.4-1 β 2.0.5-1
- ros-iron-point-cloud-transport-py: 2.0.4-1 β 2.0.5-1
- ros-iron-rmf-charger-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-charger-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-dispenser-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-dispenser-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-door-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-door-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-fleet-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-fleet-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-ingestor-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-ingestor-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-lift-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-lift-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-obstacle-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-obstacle-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-scheduler-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-scheduler-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-site-map-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-site-map-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-task: 2.2.4-1 β 2.2.5-1
- ros-iron-rmf-task-dbgsym: 2.2.4-1 β 2.2.5-1
- ros-iron-rmf-task-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-task-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-task-sequence: 2.2.4-1 β 2.2.5-1
- ros-iron-rmf-task-sequence-dbgsym: 2.2.4-1 β 2.2.5-1
- ros-iron-rmf-traffic-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-traffic-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-visualization: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-building-systems: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-fleet-states: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-fleet-states-dbgsym: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-floorplans: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-floorplans-dbgsym: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-navgraphs: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-navgraphs-dbgsym: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-obstacles: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-obstacles-dbgsym: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-rviz2-plugins: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-rviz2-plugins-dbgsym: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-schedule: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-visualization-schedule-dbgsym: 2.1.1-1 β 2.1.2-1
- ros-iron-rmf-workcell-msgs: 3.1.1-1 β 3.1.2-1
- ros-iron-rmf-workcell-msgs-dbgsym: 3.1.1-1 β 3.1.2-1
- ros-iron-rviz-assimp-vendor: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-common: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-common-dbgsym: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-default-plugins: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-default-plugins-dbgsym: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-ogre-vendor: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-ogre-vendor-dbgsym: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-rendering: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-rendering-dbgsym: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-rendering-tests: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz-visual-testing-framework: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz2: 12.4.6-1 β 12.4.7-1
- ros-iron-rviz2-dbgsym: 12.4.6-1 β 12.4.7-1
- ros-iron-simple-launch: 1.9.1-1 β 1.9.2-1
- ros-iron-spinnaker-camera-driver: 2.2.14-1 β 2.2.15-1
- ros-iron-spinnaker-camera-driver-dbgsym: 2.2.14-1 β 2.2.15-1
- ros-iron-spinnaker-synchronized-camera-driver: 2.2.14-1 β 2.2.15-1
- ros-iron-spinnaker-synchronized-camera-driver-dbgsym: 2.2.14-1 β 2.2.15-1
- ros-iron-stereo-image-proc: 4.0.0-1 β 4.0.1-1
- ros-iron-stereo-image-proc-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-tracetools-image-pipeline: 4.0.0-1 β 4.0.1-1
- ros-iron-tracetools-image-pipeline-dbgsym: 4.0.0-1 β 4.0.1-1
- ros-iron-ublox-dgnss: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-dgnss-node: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-dgnss-node-dbgsym: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-nav-sat-fix-hp-node: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-nav-sat-fix-hp-node-dbgsym: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-ubx-interfaces: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-ubx-interfaces-dbgsym: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-ubx-msgs: 0.5.2-1 β 0.5.3-1
- ros-iron-ublox-ubx-msgs-dbgsym: 0.5.2-1 β 0.5.3-1
Removed Packages [1]:
- ros-iron-microstrain-inertial-examples-dbgsym
- Aaron Chong
- Alejandro Hernandez
- Alejandro Hernandez Cordero
- Alejandro HernΓ‘ndez
- Arjo Chakravarty
- Bernd Pfrommer
- Fictionlab
- Geoff Sokoll
- Gonzalo Mier
- Grey
- Jose-Luis Blanco-Claraco
- JosΓ© Luis Blanco-Claraco
- Luis Camero
- Marco A. GutiΓ©rrez
- Morgan Quigley
- Nick Hortovanyi
- Olivier Kermorgant
- Pedro Soares
- Rob Fisher
- Rushyendra Maganty
- Vincent Rabaud
- VΓctor Mayoral-Vilches
- Yadunund
