We’re happy to announce 71 new packages and 29 updates are now available in ROS Noetic.
Thank you to every maintainer and contributor who made these updates available!
Package Updates for ROS Noetic
Added Packages [71]:
- ros-noetic-assisted-teleop: 0.3.4-1
- ros-noetic-assisted-teleop-dbgsym: 0.3.4-1
- ros-noetic-astuff-sensor-msgs: 3.1.0-1
- ros-noetic-codec-image-transport: 0.0.5-1
- ros-noetic-codec-image-transport-dbgsym: 0.0.5-1
- ros-noetic-delphi-esr-msgs: 3.1.0-1
- ros-noetic-delphi-mrr-msgs: 3.1.0-1
- ros-noetic-delphi-srr-msgs: 3.1.0-1
- ros-noetic-derived-object-msgs: 3.1.0-1
- ros-noetic-goal-passer: 0.3.4-1
- ros-noetic-goal-passer-dbgsym: 0.3.4-1
- ros-noetic-ibeo-msgs: 3.1.0-1
- ros-noetic-kartech-linear-actuator-msgs: 3.1.0-1
- ros-noetic-mir-actions: 1.1.0-1
- ros-noetic-mir-description: 1.1.0-1
- ros-noetic-mir-driver: 1.1.0-1
- ros-noetic-mir-dwb-critics: 1.1.0-1
- ros-noetic-mir-dwb-critics-dbgsym: 1.1.0-1
- ros-noetic-mir-gazebo: 1.1.0-1
- ros-noetic-mir-msgs: 1.1.0-1
- ros-noetic-mir-navigation: 1.1.0-1
- ros-noetic-mir-robot: 1.1.0-1
- ros-noetic-mobileye-560-660-msgs: 3.1.0-1
- ros-noetic-multi-object-tracking-lidar: 1.0.3-1
- ros-noetic-multi-object-tracking-lidar-dbgsym: 1.0.3-1
- ros-noetic-multisense-description: 4.0.4-1
- ros-noetic-multisense-lib: 4.0.4-1
- ros-noetic-multisense-lib-dbgsym: 4.0.4-1
- ros-noetic-navigation-experimental: 0.3.4-1
- ros-noetic-neobotix-usboard-msgs: 3.1.0-1
- ros-noetic-p2os-doc: 2.2.1-2
- ros-noetic-p2os-driver: 2.2.1-2
- ros-noetic-p2os-driver-dbgsym: 2.2.1-2
- ros-noetic-p2os-launch: 2.2.1-2
- ros-noetic-p2os-msgs: 2.2.1-2
- ros-noetic-p2os-teleop: 2.2.1-2
- ros-noetic-p2os-teleop-dbgsym: 2.2.1-2
- ros-noetic-p2os-urdf: 2.2.1-2
- ros-noetic-p2os-urdf-dbgsym: 2.2.1-2
- ros-noetic-pacmod-msgs: 3.1.0-1
- ros-noetic-pose-base-controller: 0.3.4-1
- ros-noetic-pose-base-controller-dbgsym: 0.3.4-1
- ros-noetic-pose-follower: 0.3.4-1
- ros-noetic-pose-follower-dbgsym: 0.3.4-1
- ros-noetic-rosbag-snapshot: 1.0.1-1
- ros-noetic-rosbag-snapshot-dbgsym: 1.0.1-1
- ros-noetic-rosbag-snapshot-msgs: 1.0.1-1
- ros-noetic-sbpl-lattice-planner: 0.3.4-1
- ros-noetic-sbpl-lattice-planner-dbgsym: 0.3.4-1
- ros-noetic-sbpl-recovery: 0.3.4-1
- ros-noetic-sbpl-recovery-dbgsym: 0.3.4-1
- ros-noetic-sdc21x0: 1.1.0-1
- ros-noetic-slam-toolbox: 1.5.4-1
- ros-noetic-slam-toolbox-dbgsym: 1.5.4-1
- ros-noetic-slam-toolbox-rviz: 1.5.4-1
- ros-noetic-slam-toolbox-rviz-dbgsym: 1.5.4-1
- ros-noetic-soem: 1.4.1002-1
- ros-noetic-soem-dbgsym: 1.4.1002-1
- ros-noetic-swri-image-util: 2.13.7-1
- ros-noetic-swri-image-util-dbgsym: 2.13.7-1
- ros-noetic-swri-route-util: 2.13.7-1
- ros-noetic-swri-route-util-dbgsym: 2.13.7-1
- ros-noetic-swri-transform-util: 2.13.7-1
- ros-noetic-swri-transform-util-dbgsym: 2.13.7-1
- ros-noetic-twist-recovery: 0.3.4-1
- ros-noetic-twist-recovery-dbgsym: 0.3.4-1
- ros-noetic-usb-cam-controllers: 0.0.5-1
- ros-noetic-usb-cam-controllers-dbgsym: 0.0.5-1
- ros-noetic-usb-cam-hardware: 0.0.5-1
- ros-noetic-usb-cam-hardware-dbgsym: 0.0.5-1
- ros-noetic-usb-cam-hardware-interface: 0.0.5-1
Updated Packages [29]:
- ros-noetic-marti-data-structures: 2.13.5-1 -> 2.13.7-1
- ros-noetic-rviz: 1.14.0-2 -> 1.14.1-1
- ros-noetic-rviz-dbgsym: 1.14.0-2 -> 1.14.1-1
- ros-noetic-slam-toolbox-msgs: 1.5.1-1 -> 1.5.4-1
- ros-noetic-swri-console-util: 2.13.3-1 -> 2.13.7-1
- ros-noetic-swri-console-util-dbgsym: 2.13.3-1 -> 2.13.7-1
- ros-noetic-swri-dbw-interface: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-geometry-util: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-geometry-util-dbgsym: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-math-util: 2.13.3-1 -> 2.13.7-1
- ros-noetic-swri-math-util-dbgsym: 2.13.3-1 -> 2.13.7-1
- ros-noetic-swri-nodelet: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-opencv-util: 2.13.3-1 -> 2.13.7-1
- ros-noetic-swri-opencv-util-dbgsym: 2.13.3-1 -> 2.13.7-1
- ros-noetic-swri-prefix-tools: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-roscpp: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-roscpp-dbgsym: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-rospy: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-serial-util: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-serial-util-dbgsym: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-string-util: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-string-util-dbgsym: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-system-util: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-system-util-dbgsym: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-yaml-util: 2.13.5-1 -> 2.13.7-1
- ros-noetic-swri-yaml-util-dbgsym: 2.13.5-1 -> 2.13.7-1
- ros-noetic-teleop-twist-keyboard: 0.6.2-1 -> 1.0.0-1
- ros-noetic-urg-stamped: 0.0.5-1 -> 0.0.6-1
- ros-noetic-urg-stamped-dbgsym: 0.0.5-1 -> 0.0.6-1
Removed Packages [0]:
- Atsushi Watanabe
- Austin Hendrix
- AutonomouStuff Software Team
- Carnegie Robotics
- David V. Lu!!
- Hunter L. Allen
- Kris Kozak
- Marc Alban
- Martin Günther
- Matthias Gruhler
- P. J. Reed
- Praveen Palanisamy
- Steve Macenski
- William Woodall
- Yoshito Okada
