Package Updates for humble
Added Packages [47]:
- ros-humble-grid-map: 2.0.0-1
- ros-humble-grid-map-cmake-helpers: 2.0.0-1
- ros-humble-grid-map-core: 2.0.0-1
- ros-humble-grid-map-costmap-2d: 2.0.0-1
- ros-humble-grid-map-cv: 2.0.0-1
- ros-humble-grid-map-cv-dbgsym: 2.0.0-1
- ros-humble-grid-map-demos: 2.0.0-1
- ros-humble-grid-map-demos-dbgsym: 2.0.0-1
- ros-humble-grid-map-filters: 2.0.0-1
- ros-humble-grid-map-filters-dbgsym: 2.0.0-1
- ros-humble-grid-map-loader: 2.0.0-1
- ros-humble-grid-map-loader-dbgsym: 2.0.0-1
- ros-humble-grid-map-msgs: 2.0.0-1
- ros-humble-grid-map-msgs-dbgsym: 2.0.0-1
- ros-humble-grid-map-octomap: 2.0.0-1
- ros-humble-grid-map-pcl: 2.0.0-1
- ros-humble-grid-map-pcl-dbgsym: 2.0.0-1
- ros-humble-grid-map-ros: 2.0.0-1
- ros-humble-grid-map-ros-dbgsym: 2.0.0-1
- ros-humble-grid-map-rviz-plugin: 2.0.0-1
- ros-humble-grid-map-rviz-plugin-dbgsym: 2.0.0-1
- ros-humble-grid-map-sdf: 2.0.0-1
- ros-humble-grid-map-visualization: 2.0.0-1
- ros-humble-grid-map-visualization-dbgsym: 2.0.0-1
- ros-humble-irobot-create-msgs: 2.1.0-1
- ros-humble-irobot-create-msgs-dbgsym: 2.1.0-1
- ros-humble-nlohmann-json-schema-validator-vendor: 0.1.0-2
- ros-humble-nlohmann-json-schema-validator-vendor-dbgsym: 0.1.0-2
- ros-humble-rclpy-message-converter: 2.0.0-1
- ros-humble-rclpy-message-converter-msgs: 2.0.0-1
- ros-humble-rclpy-message-converter-msgs-dbgsym: 2.0.0-1
- ros-humble-realsense2-camera-msgs: 4.51.1-1
- ros-humble-realsense2-camera-msgs-dbgsym: 4.51.1-1
- ros-humble-realsense2-description: 4.51.1-1
- ros-humble-ros-gz: 0.244.6-1
- ros-humble-ros-gz-bridge: 0.244.6-1
- ros-humble-ros-gz-bridge-dbgsym: 0.244.6-1
- ros-humble-ros-gz-image: 0.244.6-1
- ros-humble-ros-gz-image-dbgsym: 0.244.6-1
- ros-humble-ros-gz-interfaces: 0.244.6-1
- ros-humble-ros-gz-interfaces-dbgsym: 0.244.6-1
- ros-humble-ros-gz-sim: 0.244.6-1
- ros-humble-ros-gz-sim-dbgsym: 0.244.6-1
- ros-humble-ros-gz-sim-demos: 0.244.6-1
- ros-humble-system-fingerprint: 0.5.0-1
- ros-humble-tl-expected: 1.0.0-2
- ros-humble-twist-stamper: 0.0.3-1
Updated Packages [79]:
- ros-humble-controller-interface: 2.13.0-1 → 2.15.0-1
- ros-humble-controller-interface-dbgsym: 2.13.0-1 → 2.15.0-1
- ros-humble-controller-manager: 2.13.0-1 → 2.15.0-1
- ros-humble-controller-manager-dbgsym: 2.13.0-1 → 2.15.0-1
- ros-humble-controller-manager-msgs: 2.13.0-1 → 2.15.0-1
- ros-humble-controller-manager-msgs-dbgsym: 2.13.0-1 → 2.15.0-1
- ros-humble-cv-bridge: 3.0.3-2 → 3.2.1-1
- ros-humble-cv-bridge-dbgsym: 3.0.3-2 → 3.2.1-1
- ros-humble-depthai: 2.17.3-1 → 2.17.4-1
- ros-humble-depthai-dbgsym: 2.17.3-1 → 2.17.4-1
- ros-humble-eigenpy: 2.7.12-1 → 2.7.14-1
- ros-humble-eigenpy-dbgsym: 2.7.12-1 → 2.7.14-1
- ros-humble-generate-parameter-library: 0.2.4-1 → 0.2.5-1
- ros-humble-generate-parameter-library-example: 0.2.4-1 → 0.2.5-1
- ros-humble-generate-parameter-library-example-dbgsym: 0.2.4-1 → 0.2.5-1
- ros-humble-generate-parameter-library-py: 0.2.4-1 → 0.2.5-1
- ros-humble-geometry-tutorials: 0.3.4-3 → 0.3.6-1
- ros-humble-hardware-interface: 2.13.0-1 → 2.15.0-1
- ros-humble-hardware-interface-dbgsym: 2.13.0-1 → 2.15.0-1
- ros-humble-hpp-fcl: 2.1.2-2 → 2.1.3-1
- ros-humble-hpp-fcl-dbgsym: 2.1.2-2 → 2.1.3-1
- ros-humble-image-geometry: 3.0.3-2 → 3.2.1-1
- ros-humble-image-geometry-dbgsym: 3.0.3-2 → 3.2.1-1
- ros-humble-joint-limits: 2.13.0-1 → 2.15.0-1
- ros-humble-joint-limits-dbgsym: 2.13.0-1 → 2.15.0-1
- ros-humble-leo-bringup: 1.1.0-1 → 1.2.0-1
- ros-humble-leo-desktop: 1.0.0-1 → 1.1.0-1
- ros-humble-leo-fw: 1.1.0-1 → 1.2.0-1
- ros-humble-leo-fw-dbgsym: 1.1.0-1 → 1.2.0-1
- ros-humble-leo-robot: 1.1.0-1 → 1.2.0-1
- ros-humble-leo-viz: 1.0.0-1 → 1.1.0-1
- ros-humble-microstrain-inertial-driver: 2.6.0-1 → 2.7.0-1
- ros-humble-microstrain-inertial-driver-dbgsym: 2.6.0-1 → 2.7.0-1
- ros-humble-microstrain-inertial-examples: 2.6.0-1 → 2.7.0-1
- ros-humble-microstrain-inertial-examples-dbgsym: 2.6.0-1 → 2.7.0-1
- ros-humble-microstrain-inertial-msgs: 2.6.0-1 → 2.7.0-1
- ros-humble-microstrain-inertial-msgs-dbgsym: 2.6.0-1 → 2.7.0-1
- ros-humble-microstrain-inertial-rqt: 2.6.0-1 → 2.7.0-1
- ros-humble-parameter-traits: 0.2.4-1 → 0.2.5-1
- ros-humble-ros-ign: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-bridge: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-bridge-dbgsym: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-gazebo: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-gazebo-dbgsym: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-gazebo-demos: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-image: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-image-dbgsym: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-interfaces: 0.244.3-1 → 0.244.6-1
- ros-humble-ros-ign-interfaces-dbgsym: 0.244.3-1 → 0.244.6-1
- ros-humble-ros2-control: 2.13.0-1 → 2.15.0-1
- ros-humble-ros2-control-test-assets: 2.13.0-1 → 2.15.0-1
- ros-humble-ros2controlcli: 2.13.0-1 → 2.15.0-1
- ros-humble-rplidar-ros: 2.0.3-1 → 2.1.0-1
- ros-humble-rplidar-ros-dbgsym: 2.0.3-1 → 2.1.0-1
- ros-humble-rqt-graph: 1.2.1-3 → 1.3.0-1
- ros-humble-rqt-msg: 1.0.6-2 → 1.2.0-1
- ros-humble-rqt-reconfigure: 1.0.8-3 → 1.1.1-1
- ros-humble-rqt-topic: 1.2.3-2 → 1.5.0-1
- ros-humble-rviz-assimp-vendor: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-common: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-common-dbgsym: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-default-plugins: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-default-plugins-dbgsym: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-ogre-vendor: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-ogre-vendor-dbgsym: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-rendering: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-rendering-dbgsym: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-rendering-tests: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz-visual-testing-framework: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz2: 11.2.2-1 → 11.2.3-1
- ros-humble-rviz2-dbgsym: 11.2.2-1 → 11.2.3-1
- ros-humble-slider-publisher: 2.1.1-1 → 2.2.0-1
- ros-humble-tcb-span: 0.2.4-1 → 1.0.0-2
- ros-humble-transmission-interface: 2.13.0-1 → 2.15.0-1
- ros-humble-transmission-interface-dbgsym: 2.13.0-1 → 2.15.0-1
- ros-humble-turtle-tf2-cpp: 0.3.4-3 → 0.3.6-1
- ros-humble-turtle-tf2-cpp-dbgsym: 0.3.4-3 → 0.3.6-1
- ros-humble-turtle-tf2-py: 0.3.4-3 → 0.3.6-1
- ros-humble-vision-opencv: 3.0.3-2 → 3.2.1-1
Removed Packages [0]:
- Alberto Soragna
- Alejandro Hernandez
- Alejandro Hernández Cordero
- Audrow Nash
- Bence Magyar
- Brandon Ong
- David V. Lu!!
- Fictionlab
- Grey
- Hunter L. Allen
- Jacob Perron
- Joseph Mirabel
- Josh Newans
- Justin Carpentier
- Kenji Brameld
- LibRealSense ROS Team
- Louise Poubel
- Martin Günther
- Maximilian Wulf
- Michael Jeronimo
- Olivier Kermorgant
- Paul Gesel
- Rob Fisher
- Sachin Guruswamy
- Scott K Logan
- Tyler Weaver
