I am a civil engineer currently pursuing a PhD and am looking for an experienced ROS expert to assist with a long-term project involving ROS2 and autonomous robotics.
Project Overview:
I am working on a project where I need to implement a robot (such as Turtlebot3) to perform 3D laser scanning to generate point clouds. These point clouds will be used to measure construction progress on a site.
Current Progress:
- I am using RTAB-MAP and Turtlebot3 to generate point clouds.
- The next step is to employ autonomous exploration strategies (e.g., frontier-based) to enable the robot to fully scan a construction site and produce comprehensive point clouds.
Assistance Required:
I am seeking assistance with the following:
- Implementing and fine-tuning autonomous exploration strategies.
- Providing ongoing support as the project progresses.
Additional Information:
- Flexibility: I am open to using any version of ROS, alternative robots, or other adjustments necessary to achieve the project’s objectives. My primary goal is to successfully complete the project, so I am flexible with the tools and approaches used.
Interested Candidates:
If you are interested in this opportunity, please provide the following details:
- Your availability and the fees you would require.
- Your preferred method of proceeding and any information you may need from me.
- Your willingness to have an initial Zoom meeting to discuss the project in more detail.
Thank you for considering this opportunity. I look forward to your response and hope we can collaborate on this exciting project.
