[TB4] Who Knew SSIDs Are Case Sensitive?
Am I the only person that did not know SSIDs are case sensitive?
Had one chance to setup my new #Turtlebot4lite Raspberry Pi4’s WiFi without using wired Ethernet, and I blew it.
Luckily, had a laptop I could setup with a static IP, and luckily the TurbleBot4lite’s RPi4 is mounted with the Ethernet connector toward the outside, and luckily the drawer with the RPi4 can be opened enough to plug in an Ethernet cable.
Step 1: Connect TB4lite RPi4 to 5GHz WiFi done.
Now to Connect the TB4lite’s Create3 base to my 2.4GHz WiFi.
