We have just patched industrial_ci to deal with the recent ROS security updates.
While most test jobs should work as-is, some actions need to be taken to fix broken builds and/or make your configuration future-proof (indigo and lunar EOL, colcon/ROS2 support):
Repository keys
The GPG keys have been rotated.
If your config overwrites APTKEY_STORE_HTTPS
or HASHKEY_SKS
, you might have to update these settings (or remove them).
Branch management
In preparation of the upcoming colcon/ROS2 support, the current master
branch was renamed to legacy
. If your CI config clones the master
branch explicitly, you should clone legacy
instead or go with the default branch.
Eventually, the latter will point to the new version, which drops support for ROS hydro and might need additional migration (preview).
Snapshot/shadow repository
EOL distros have been moved to the snapshot repository and the shadow repository got renamed.
If your config specifies ROS_PACKAGE_PATH
and points to one of the official repositories, better use ROS_REPO
instead:
ROS_REPO=main
(orROS_REPO=ros
) to use the default repository. -
ROS_REPO=testing
(orROS_REPO=ros-testing
orROS_REPO=ros-shadow-fixed
) to use the testing/shadow-fixed repository.
This will switch your test jobs to the final snapshot once a distro reaches end-of-life.
To enforce this explicitly, you can set ROS_REPO=final
(only if distro is EOL) or ROS_REPO=YYYY-MM-DD
(snapshot timestamp).
If you face any problem that is not (yet) covered here, please don’t hesitate to open a new issue!
