Any body else count the number of times ROS appeared on camera? I spotted a number of screens running rviz and I think rosbag.
Any one know what version of ROS they use internally, or what kind of backend they showed for simulation?
ROS Resources: Documentation | Support | Discussion Forum | Service Status | Q&A answers.ros.org |
Just curious, is it ROS1 or ROS2?
Is that RViz?
Reads like Director to me. The interactive markers are too “thin” and I don’t recognise any of those panels, nor the buttons:
Not everything with a Grid and a pointcloud render is RViz
I feel bait and switched with the lumber on the table saw. I was about to be very impressed if they could make Altas cut something that large reliably and operate the saw
I hoped to see PlotJuggler at any moment, but nope.
They unfortunately don’t use ROS. I believe it is a homemade implementation using gRPC, but I do know they use an RViz-like tool for a lot for their work. They are also still using Ubuntu 18.04 until they finish tests with 20.04.
I believe it is GitHub - RobotLocomotion/director: A robotics interface and visualization framework, with extensive applications for working with http://drake.mit.edu. See https://groups.csail.mit.edu/robotics-center/public_papers/Marion16.pdf for screenshots and specifically compare the end-effector widget in figure 4.
