๐Ÿค– Introducing MoboBot: An Open-source ROS2 Mobile Robot for Hands-on Learning and Development
Hi ROS Community,
Iโ€™d like to introduce MoboBot, an open-source ROS2 mobile robot designed to make hands-on robotics more accessible, especially in Nigeria and Africa where getting started with advanced robotics can be quite challenging.
This will foster hands-on learning of advanced mobile robotics concepts such as sensor fusion, control, state estimation, localization, SLAM, Navigation, perception, etc. ensuring the longevity and future of open-source robotics in Nigeria and Africa, and beyond.
๐—ž๐—ฒ๐˜† ๐—™๐—ฒ๐—ฎ๐˜๐˜‚๐—ฟ๐—ฒ๐˜€:
:white_check_mark: Powered by Raspberry Pi 4B for onboard processing
:white_check_mark: RPLidar for SLAM, AMCL, and Navigation (๐˜ฑ๐˜ณ๐˜ฆ-๐˜ค๐˜ฐ๐˜ฏ๐˜ง๐˜ช๐˜จ๐˜ถ๐˜ณ๐˜ฆ๐˜ฅ ๐˜ธ๐˜ช๐˜ต๐˜ฉ Nav2)
:white_check_mark: It uses the EPMC Module and EIMU Module for its base control and sensor fusion (EKF).
:white_check_mark: USB Camera for OpenCV + ROS2 perception and camera streaming
:white_check_mark: Ignition Gazebo Simulation environment for algorithm test before implementation.
:white_check_mark: Easy to work with and build.
:pushpin: MoboBot is still under development, so contributions from the community would be valued. Stay tuned for more updates.
In the meantime, you can explore the simulation and documentation here
I would love to hear your thoughts on how you think MoboBot can shape robotics In Nigeria, Africa, and beyond, or if you have any question or suggestions. Thank you.
mobo_test
Awesome work, Sam :clap: . Looking forward to when the full product will be available.
Great work and love the documentation. This would serve as a great โ€œgetting startedโ€ platform for anybody in the community. Thanks for contributing!
