We are pleased to announce at Computex Taipei the release of Isaac ROS 3.0 with major updates including new packages, performance improvements and fixes.
The Isaac ROS update for ROS 2 Humble is available at github.com/NVIDIA-ISAAC-ROS, including packages for AI perception, image & LIDAR processing, navigation and adds:
- New! workflows for robot arms with Isaac Manipulator and AMR’s with Isaac Perceptor.
- New! package cuMotion for MoveIt 2 providing hardware accelerated motion planning with collision avoidance with obstacles.
- New! FoundationPose DNN for pose_estimation and tracking of unseen objects from a 3D model of the object.
- New! Multi-camera visual odometry providing robust visual tracking.
- New! Multi-camera nvBlox 3D reconstruction for costmaps used in motion planning with Nav2 and MoveIt 2.
- New! Segformer and SAM (Segment Anything) DNN packages for transformer based image_segmentation.
- New! data_recorder for multi-sensor data capture to ROSBag using MCAP and data_replayer for AI and perception development with time synchronized real sensor data at 500+ mega samples per second.
- New! Software for out of the box ROS 2 development with Nova Orin Developer Kit to stop losing time on system software and drivers.
- Updated ESS 4.0 stereo depth estimation DNN with improved accuracy, mobile robot and manipulation use cases with higher performance at >100 frames per second.
- Performance improvements with event based scheduling for NITROS.
- Bonus! tutorial for new Nav 2 docking
feature with mission_dispatch on the cloud connected over VDA5050 to mission_client.
- Update to Jetpack 6.0 with Ubuntu 22.04 with real-time optimizations and CUDA 12.2
- Bug fixes
nvBlox visualization of cuboid reconstruction with multi-camera perception to avoid obstacles missed by planar LIDAR.
FoundationPose detection on challenging objects with symmetry, reflections, specular highlights, and camera motion blur.
ESS 4.0, AI based depth estimation for manipulation and AMR applications.
Isaac ROS 3.0 is available now at github.com/NVIDIA-ISAAC-ROS and is part of our commitment to provide features and hardware acceleration for commercial deployment, development and research for autonomous robots.
Install pre-built Debian packages, leverage the Isaac ROS Dev container, or clone the repositories you need into your ROS workspace to build from source with colcon alongside your other ROS 2 packages. Please note that this release has been tested on the NVIDIA Jetson AGX Orin with JetPack 6.0. For more details see the release notes.
A minor hotfix will be released this June with the next major release in Oct at ROSCon 2024.
