I’m hoping that this RMW layer will eventually be accepted as a ROS2 package, move to the ROS2 repositories and become part of the set of packages that is built by default, but until then, it’ll be available in this location. Also, it is really still very young, so please test the hell out of it and then be gentle with me when you report the issues you will inevitably encounter …
To build/use it you need to have a recent commit of Cyclone DDS installed somewhere, say in $CMAKE_INSTALL_PREFIX. Actually building the RMW implementation then follows the standard procedure: clone it in a ROS2 workspace source directory, set CycloneDDS=$CMAKE_INSTALL_PREFIX/share/CycloneDDS and build with colcon as usual.
update: Eclipse Cyclone DDS has been refactored to build easily with ROS 2 using colcon. Drop it in and build it, try it and give feedback. We really like GitHub issues😁 rmw_cyclonedds is being contributed in ROS 2 Eloquent.
tip: if your wifi has problems with multicast, then configuring DDS to use multicast only for discovery (SPDP - Simple Endpoint Discovery Protocol) can fix that
excerpted from another thread, @eboasson says: Eclipse Cyclone DDS today gives you a pretty decent small message latency over loopback on 8 year old 3.5GHz Xeon E3-1270 running Ubuntu 16 … you see it comes out rather well for the small ones, even though it uses the loopback interface, and fares not so badly against the latencies mentioned earlier using a shared memory transport for the large ones.
[0] median latency as measured by doing round-trips as fast as possible and halving the measured round-trip time, using reliable communications …
[1] keyless topic of one int32_t, the others have an int32_t key field
(always set to 0) and an octet sequence;
[2] this is with a fragmenting threshold set large enough to not fragment the ones that fit in a single UDP datagram; with the default setting the numbers are worse.
ROS 2 dashing w Eclipse Cyclone RMW powered Rover Robotics AMR + industrial controller are working reliably via WiFi at the Intel + ADLINK + AWS RoboMaker exhibit at Pack Expo despite 666 WiFi APs covering that section of Las Vegas Convention Center. @eboasson says “that is a devilish number of APs”
ros2/rmw_cyclonedds working reliably under challenging wifi conditions is consistent with results of testing by @rotu and other ros2 contributors
@alsora@joxoby gave terrific talk at ROScon about iRobot using ros2/rmw_cyclonedds, said it beats all iRobot performance targets for low latency, reliability and low RAM. They worked out how to scale fleets using cyclonedds and contributed a new intra-process manager to dashing.
