Ros-drivers/audio_common bug fixes
there are several bug fix PRs on ros-drivers/audio_common repository, but no one is responding.
I want someone to move forward these PRs.
I don’t know which team is maintaining this repository, but the repo is under ros-drivers organization, so I add drivers tag.
@knorth55 any interest in maintaining it? From glancing over your PRs and the repo, it looks awfully unmaintained. If this is important to you & you rely on it, you may consider petitioning for maintainership/admin on the repo.
@tfoote
@smac Yes, @k-okada and I are interested in maintaining the repository. Our robot system heavily relies on audio_common repo, so the maintenance quality of the repo is a big issue for us, too.
@knorth55 good to point that out
I’ve opened an issue on the repository to see if the current maintainer is willing to share maintainership: https://github.com/ros-drivers/audio_common/issues/130 . We’ll see what comes back.
Sorry; I haven’t really had time to manage the bug reports or contributions to audio_common for a while. I’ve granted @k-okada and @knorth55 write access to this repository and https://github.com/ros-gbp/audio_common-release so that they can do maintenance and releases.
Thanks for being responsive and granting access to other contributors!
@trainman419 @clalancette Thank you very much for giving access!
