ROS2 Rust Node
Hi folks - I wanted to thank you all for your work on Rust in ROS2! It took me a little research to find ros2_rust, but once I did it was easy to set up and build. I was able to make a video on it with a basic node because of your efforts. I’ll be joining the working group and hopefully making more content about Rust in ROS2 - let me know if you have anything that you want to make videos on as well.
Again, appreciate your efforts.
