Wifi & Lossy networks Solutions: Flow controllers
Hi everybody!
Just wanted to share with you the new Fast DDS feature Flow Controllers, a solution designed to avoid bursts of data that could collapse your network when using wifi and lossy network solutions.
This mechanism enables the limitation of the rate at which the data is sent by a DataWriter, this way it avoids network overloads in the connection to the data writer, so users don’t have to worry about send retries and NACK messages.
Find more info at: Fast DDS Flow Controllers
