Package Updates for humble
Added Packages [52]:
- ros-humble-admittance-controller: 2.15.0-1
- ros-humble-admittance-controller-dbgsym: 2.15.0-1
- ros-humble-ament-black: 0.1.0-1
- ros-humble-ament-cmake-black: 0.1.0-1
- ros-humble-dataspeed-can: 2.0.1-1
- ros-humble-dataspeed-can-msg-filters: 2.0.1-1
- ros-humble-dataspeed-can-usb: 2.0.1-1
- ros-humble-dataspeed-can-usb-dbgsym: 2.0.1-1
- ros-humble-dataspeed-dbw-common: 2.1.0-1
- ros-humble-dataspeed-dbw-msgs: 2.1.0-1
- ros-humble-dataspeed-dbw-msgs-dbgsym: 2.1.0-1
- ros-humble-dataspeed-ulc: 2.1.0-1
- ros-humble-dataspeed-ulc-can: 2.1.0-1
- ros-humble-dataspeed-ulc-can-dbgsym: 2.1.0-1
- ros-humble-dataspeed-ulc-msgs: 2.1.0-1
- ros-humble-dataspeed-ulc-msgs-dbgsym: 2.1.0-1
- ros-humble-dbw-fca-description: 2.1.0-1
- ros-humble-dbw-fca-msgs: 2.1.0-1
- ros-humble-dbw-fca-msgs-dbgsym: 2.1.0-1
- ros-humble-dbw-ford-description: 2.1.0-1
- ros-humble-dbw-ford-msgs: 2.1.0-1
- ros-humble-dbw-ford-msgs-dbgsym: 2.1.0-1
- ros-humble-dbw-polaris-description: 2.1.0-1
- ros-humble-dbw-polaris-msgs: 2.1.0-1
- ros-humble-dbw-polaris-msgs-dbgsym: 2.1.0-1
- ros-humble-foros: 0.4.1-2
- ros-humble-foros-dbgsym: 0.4.1-2
- ros-humble-foros-examples: 0.4.1-2
- ros-humble-foros-examples-dbgsym: 0.4.1-2
- ros-humble-foros-inspector: 0.4.1-2
- ros-humble-foros-inspector-dbgsym: 0.4.1-2
- ros-humble-foros-msgs: 0.4.1-2
- ros-humble-foros-msgs-dbgsym: 0.4.1-2
- ros-humble-foxglove-bridge: 0.2.2-1
- ros-humble-foxglove-bridge-dbgsym: 0.2.2-1
- ros-humble-lusb: 2.0.1-1
- ros-humble-lusb-dbgsym: 2.0.1-1
- ros-humble-magic-enum: 0.8.2-1
- ros-humble-realtime-tools-dbgsym: 2.4.0-1
- ros-humble-rqt-controller-manager: 2.18.0-1
- ros-humble-rsl-dbgsym: 0.2.1-1
- ros-humble-rtcm-msgs: 1.1.6-1
- ros-humble-rtcm-msgs-dbgsym: 1.1.6-1
- ros-humble-tiago-2dnav: 4.0.1-1
- ros-humble-tiago-bringup: 4.0.1-1
- ros-humble-tiago-controller-configuration: 4.0.1-1
- ros-humble-tiago-description: 4.0.1-1
- ros-humble-tiago-gazebo: 4.0.0-1
- ros-humble-tiago-moveit-config: 3.0.0-1
- ros-humble-tiago-navigation: 4.0.1-1
- ros-humble-tiago-robot: 4.0.1-1
- ros-humble-tiago-simulation: 4.0.0-1
Updated Packages [221]:
- ros-humble-camera-calibration-parsers: 3.1.4-2 → 3.1.5-1
- ros-humble-camera-calibration-parsers-dbgsym: 3.1.4-2 → 3.1.5-1
- ros-humble-camera-info-manager: 3.1.4-2 → 3.1.5-1
- ros-humble-camera-info-manager-dbgsym: 3.1.4-2 → 3.1.5-1
- ros-humble-chomp-motion-planner: 2.5.3-1 → 2.5.4-1
- ros-humble-chomp-motion-planner-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-control-toolbox: 2.1.1-1 → 2.1.2-1
- ros-humble-control-toolbox-dbgsym: 2.1.1-1 → 2.1.2-1
- ros-humble-controller-interface: 2.16.0-1 → 2.18.0-1
- ros-humble-controller-interface-dbgsym: 2.16.0-1 → 2.18.0-1
- ros-humble-controller-manager: 2.16.0-1 → 2.18.0-1
- ros-humble-controller-manager-dbgsym: 2.16.0-1 → 2.18.0-1
- ros-humble-controller-manager-msgs: 2.16.0-1 → 2.18.0-1
- ros-humble-controller-manager-msgs-dbgsym: 2.16.0-1 → 2.18.0-1
- ros-humble-depthai: 2.19.0-1 → 2.19.1-1
- ros-humble-depthai-dbgsym: 2.19.0-1 → 2.19.1-1
- ros-humble-diff-drive-controller: 2.12.0-1 → 2.15.0-1
- ros-humble-diff-drive-controller-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-effort-controllers: 2.12.0-1 → 2.15.0-1
- ros-humble-effort-controllers-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-eigenpy: 2.7.14-1 → 2.8.1-1
- ros-humble-eigenpy-dbgsym: 2.7.14-1 → 2.8.1-1
- ros-humble-fastrtps: 2.6.2-1 → 2.6.3-1
- ros-humble-fastrtps-dbgsym: 2.6.2-1 → 2.6.3-1
- ros-humble-force-torque-sensor-broadcaster: 2.12.0-1 → 2.15.0-1
- ros-humble-force-torque-sensor-broadcaster-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-forward-command-controller: 2.12.0-1 → 2.15.0-1
- ros-humble-forward-command-controller-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-foxglove-msgs: 2.0.0-1 → 2.1.1-1
- ros-humble-foxglove-msgs-dbgsym: 2.0.0-1 → 2.1.1-1
- ros-humble-generate-parameter-library: 0.2.8-1 → 0.3.0-1
- ros-humble-generate-parameter-library-example: 0.2.8-1 → 0.3.0-1
- ros-humble-generate-parameter-library-example-dbgsym: 0.2.8-1 → 0.3.0-1
- ros-humble-generate-parameter-library-py: 0.2.8-1 → 0.3.0-1
- ros-humble-gripper-controllers: 2.12.0-1 → 2.15.0-1
- ros-humble-gripper-controllers-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-gurumdds-cmake-module: 3.1.1-1 → 3.3.1-1
- ros-humble-hardware-interface: 2.16.0-1 → 2.18.0-1
- ros-humble-hardware-interface-dbgsym: 2.16.0-1 → 2.18.0-1
- ros-humble-hey5-description: 3.0.1-1 → 3.0.2-1
- ros-humble-hpp-fcl: 2.1.3-1 → 2.2.0-1
- ros-humble-hpp-fcl-dbgsym: 2.1.3-1 → 2.2.0-1
- ros-humble-image-common: 3.1.4-2 → 3.1.5-1
- ros-humble-image-transport: 3.1.4-2 → 3.1.5-1
- ros-humble-image-transport-dbgsym: 3.1.4-2 → 3.1.5-1
- ros-humble-imu-complementary-filter: 2.1.1-2 → 2.1.3-1
- ros-humble-imu-complementary-filter-dbgsym: 2.1.1-2 → 2.1.3-1
- ros-humble-imu-filter-madgwick: 2.1.1-2 → 2.1.3-1
- ros-humble-imu-filter-madgwick-dbgsym: 2.1.1-2 → 2.1.3-1
- ros-humble-imu-sensor-broadcaster: 2.12.0-1 → 2.15.0-1
- ros-humble-imu-sensor-broadcaster-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-imu-tools: 2.1.1-2 → 2.1.3-1
- ros-humble-joint-limits: 2.16.0-1 → 2.18.0-1
- ros-humble-joint-limits-dbgsym: 2.16.0-1 → 2.18.0-1
- ros-humble-joint-state-broadcaster: 2.12.0-1 → 2.15.0-1
- ros-humble-joint-state-broadcaster-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-joint-trajectory-controller: 2.12.0-1 → 2.15.0-1
- ros-humble-joint-trajectory-controller-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-joy-teleop: 1.2.1-3 → 1.3.0-1
- ros-humble-key-teleop: 1.2.1-3 → 1.3.0-1
- ros-humble-leo-bringup: 1.2.0-1 → 1.2.1-1
- ros-humble-leo-fw: 1.2.0-1 → 1.2.1-1
- ros-humble-leo-fw-dbgsym: 1.2.0-1 → 1.2.1-1
- ros-humble-leo-robot: 1.2.0-1 → 1.2.1-1
- ros-humble-marvelmind-ros2: 1.0.2-3 → 1.0.3-5
- ros-humble-marvelmind-ros2-dbgsym: 1.0.2-3 → 1.0.3-5
- ros-humble-mcap-vendor: 0.5.0-1 → 0.6.0-1
- ros-humble-mcap-vendor-dbgsym: 0.5.0-1 → 0.6.0-1
- ros-humble-microstrain-inertial-driver: 2.7.0-1 → 2.7.1-1
- ros-humble-microstrain-inertial-driver-dbgsym: 2.7.0-1 → 2.7.1-1
- ros-humble-microstrain-inertial-examples: 2.7.0-1 → 2.7.1-1
- ros-humble-microstrain-inertial-examples-dbgsym: 2.7.0-1 → 2.7.1-1
- ros-humble-microstrain-inertial-msgs: 2.7.0-1 → 2.7.1-1
- ros-humble-microstrain-inertial-msgs-dbgsym: 2.7.0-1 → 2.7.1-1
- ros-humble-microstrain-inertial-rqt: 2.7.0-1 → 2.7.1-1
- ros-humble-mouse-teleop: 1.2.1-3 → 1.3.0-1
- ros-humble-moveit: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-chomp-optimizer-adapter: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-chomp-optimizer-adapter-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-common: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-configs-utils: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-core: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-core-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-hybrid-planning: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-hybrid-planning-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-kinematics: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-kinematics-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-planners: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-planners-chomp: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-planners-chomp-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-planners-ompl: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-planners-ompl-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-plugins: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-resources-prbt-ikfast-manipulator-plugin: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-resources-prbt-ikfast-manipulator-plugin-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-resources-prbt-moveit-config: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-resources-prbt-pg70-support: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-resources-prbt-support: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-benchmarks: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-benchmarks-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-control-interface: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-control-interface-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-move-group: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-move-group-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-occupancy-map-monitor: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-occupancy-map-monitor-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-perception: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-perception-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-planning: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-planning-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-planning-interface: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-planning-interface-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-robot-interaction: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-robot-interaction-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-visualization: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-visualization-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-warehouse: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-ros-warehouse-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-runtime: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-servo: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-servo-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-app-plugins: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-app-plugins-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-assistant: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-assistant-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-controllers: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-controllers-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-core-plugins: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-core-plugins-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-framework: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-framework-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-srdf-plugins: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-setup-srdf-plugins-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-simple-controller-manager: 2.5.3-1 → 2.5.4-1
- ros-humble-moveit-simple-controller-manager-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-mrpt2: 2.5.4-1 → 2.5.7-1
- ros-humble-mrpt2-dbgsym: 2.5.4-1 → 2.5.7-1
- ros-humble-mvsim: 0.4.2-1 → 0.4.3-1
- ros-humble-mvsim-dbgsym: 0.4.2-1 → 0.4.3-1
- ros-humble-nlohmann-json-schema-validator-vendor: 0.2.1-1 → 0.2.4-1
- ros-humble-nlohmann-json-schema-validator-vendor-dbgsym: 0.2.1-1 → 0.2.4-1
- ros-humble-parameter-traits: 0.2.8-1 → 0.3.0-1
- ros-humble-pilz-industrial-motion-planner: 2.5.3-1 → 2.5.4-1
- ros-humble-pilz-industrial-motion-planner-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-pilz-industrial-motion-planner-testutils: 2.5.3-1 → 2.5.4-1
- ros-humble-pilz-industrial-motion-planner-testutils-dbgsym: 2.5.3-1 → 2.5.4-1
- ros-humble-pmb2-gazebo: 4.0.0-1 → 4.0.1-1
- ros-humble-pmb2-simulation: 4.0.0-1 → 4.0.1-1
- ros-humble-position-controllers: 2.12.0-1 → 2.15.0-1
- ros-humble-position-controllers-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-pybind11-json-vendor: 0.2.0-1 → 0.2.2-1
- ros-humble-pybind11-vendor: 2.4.1-1 → 2.4.2-1
- ros-humble-rclpy-message-converter: 2.0.0-1 → 2.0.1-1
- ros-humble-rclpy-message-converter-msgs: 2.0.0-1 → 2.0.1-1
- ros-humble-rclpy-message-converter-msgs-dbgsym: 2.0.0-1 → 2.0.1-1
- ros-humble-realtime-tools: 2.2.0-3 → 2.4.0-1
- ros-humble-rmw-gurumdds-cpp: 3.2.0-1 → 3.3.1-1
- ros-humble-rmw-gurumdds-cpp-dbgsym: 3.2.0-1 → 3.3.1-1
- ros-humble-ros2-control: 2.16.0-1 → 2.18.0-1
- ros-humble-ros2-control-test-assets: 2.16.0-1 → 2.18.0-1
- ros-humble-ros2-controllers: 2.12.0-1 → 2.15.0-1
- ros-humble-ros2-controllers-test-nodes: 2.12.0-1 → 2.15.0-1
- ros-humble-ros2controlcli: 2.16.0-1 → 2.18.0-1
- ros-humble-rosbag2-storage-mcap: 0.5.0-1 → 0.6.0-1
- ros-humble-rosbag2-storage-mcap-dbgsym: 0.5.0-1 → 0.6.0-1
- ros-humble-rosbag2-storage-mcap-testdata: 0.5.0-1 → 0.6.0-1
- ros-humble-rosbag2-storage-mcap-testdata-dbgsym: 0.5.0-1 → 0.6.0-1
- ros-humble-rqt-joint-trajectory-controller: 2.12.0-1 → 2.15.0-1
- ros-humble-rsl: 0.1.1-1 → 0.2.1-1
- ros-humble-rtabmap: 0.20.21-1 → 0.20.22-1
- ros-humble-rtabmap-dbgsym: 0.20.21-1 → 0.20.22-1
- ros-humble-rtabmap-ros: 0.20.20-2 → 0.20.22-1
- ros-humble-rtabmap-ros-dbgsym: 0.20.20-2 → 0.20.22-1
- ros-humble-rviz-imu-plugin: 2.1.1-2 → 2.1.3-1
- ros-humble-rviz-imu-plugin-dbgsym: 2.1.1-2 → 2.1.3-1
- ros-humble-septentrio-gnss-driver: 1.2.2-5 → 1.2.3-1
- ros-humble-septentrio-gnss-driver-dbgsym: 1.2.2-5 → 1.2.3-1
- ros-humble-teleop-tools: 1.2.1-3 → 1.3.0-1
- ros-humble-teleop-tools-msgs: 1.2.1-3 → 1.3.0-1
- ros-humble-teleop-tools-msgs-dbgsym: 1.2.1-3 → 1.3.0-1
- ros-humble-transmission-interface: 2.16.0-1 → 2.18.0-1
- ros-humble-transmission-interface-dbgsym: 2.16.0-1 → 2.18.0-1
- ros-humble-tricycle-controller: 2.12.0-1 → 2.15.0-1
- ros-humble-tricycle-controller-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-tvm-vendor: 0.9.0-1 → 0.9.1-1
- ros-humble-tvm-vendor-dbgsym: 0.9.0-1 → 0.9.1-1
- ros-humble-ur: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-bringup: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-calibration: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-calibration-dbgsym: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-client-library: 1.2.0-1 → 1.3.1-1
- ros-humble-ur-client-library-dbgsym: 1.2.0-1 → 1.3.1-1
- ros-humble-ur-controllers: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-controllers-dbgsym: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-dashboard-msgs: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-dashboard-msgs-dbgsym: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-moveit-config: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-robot-driver: 2.2.5-1 → 2.2.6-1
- ros-humble-ur-robot-driver-dbgsym: 2.2.5-1 → 2.2.6-1
- ros-humble-velocity-controllers: 2.12.0-1 → 2.15.0-1
- ros-humble-velocity-controllers-dbgsym: 2.12.0-1 → 2.15.0-1
- ros-humble-velodyne-description: 2.0.2-3 → 2.0.3-1
- ros-humble-velodyne-gazebo-plugins: 2.0.2-3 → 2.0.3-1
- ros-humble-velodyne-gazebo-plugins-dbgsym: 2.0.2-3 → 2.0.3-1
- ros-humble-velodyne-simulator: 2.0.2-3 → 2.0.3-1
- ros-humble-webots-ros2: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-control: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-control-dbgsym: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-driver: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-driver-dbgsym: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-epuck: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-importer: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-mavic: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-msgs: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-msgs-dbgsym: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-tesla: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-tests: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-tiago: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-turtlebot: 2022.1.3-1 → 2023.0.0-1
- ros-humble-webots-ros2-universal-robot: 2022.1.3-1 → 2023.0.0-1
Removed Packages [3]:
- ros-humble-rmw-gurumdds-shared-cpp
- ros-humble-rmw-gurumdds-shared-cpp-dbgsym
- ros-humble-webots-ros2-core
- Alejandro Hernandez Cordero
- Alexander Gutenkunst
- Bence Magyar
- Blake Anderson
- Chittaranjan Srinivas Swaminathan
- Christian Henkel
- Cyberbotics
- David V. Lu!!
- Denis Stogl
- Denis Štogl
- Enrique Fernandez
- Felix Exner
- Fictionlab
- Foxglove
- Grey
- Henning Kayser
- James Smith
- John Hurliman
- Jordan Palacios
- Jordi Pages
- Jose-Luis Blanco-Claraco
- Joseph Mirabel
- Josh Whitley
- Justin Carpentier
- Kevin Hallenbeck
- Marek Materzok
- Martin Günther
- Mathieu Labbe
- Michael Görner
- Micho Radovnikovich
- Miguel Company
- MoveIt Release Team
- Neargye
- Paul Gesel
- Raghavender Sahdev
- Rob Fisher
- Sachin Guruswamy
- Septentrio
- Shane Loretz
- TIAGo PAL support team
- Tim Clephas
- Tyler Weaver
- Wonguk Jeong
- YouLiang
- Youngjin Yun
- jetson
