thanks for the hint, I’ve been doing tests and I’ve seen that this particular topic is empty, but I was missing all /config /… topics.
However I still can not get it to work, I isolated the error and it occurs when launching the ndt_matching
jcs@PC1:~$ roslaunch lidar_localizer ndt_matching.launch
... logging to /home/jcs/.ros/log/1134959a-5077-11e9-9a93-7062b8945ad9/roslaunch-PC1-24173.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://192.168.20.110:40779/
SUMMARY
PARAMETERS
* /ndt_matching/get_height: False
* /ndt_matching/imu_topic: /imu_raw
* /ndt_matching/imu_upside_down: False
* /ndt_matching/method_type: 0
* /ndt_matching/offset: linear
* /ndt_matching/queue_size: 1
* /ndt_matching/use_gnss: 1
* /ndt_matching/use_imu: False
* /ndt_matching/use_local_transform: False
* /ndt_matching/use_odom: False
* /rosdistro: kinetic
* /rosversion: 1.12.14
NODES
ndt_matching (lidar_localizer/ndt_matching)
ROS_MASTER_URI=http://192.168.20.110:11311
process[ndt_matching-1]: started with pid [24212]
Warning: Invalid argument passed to canTransform argument source_frame in tf2 frame_ids cannot be empty
at line 126 in /tmp/binarydeb/ros-kinetic-tf2-0.5.20/src/buffer_core.cpp
jcs@PC1:~$ rostopic echo /config/ndt
header:
seq: 2
stamp:
secs: 0
nsecs: 0
frame_id: ''
init_pos_gnss: 0
x: 45.0
y: 0.0
z: 0.0
roll: 0.0
pitch: -0.0121999997646
yaw: 0.0
use_predict_pose: 0
error_threshold: 0.10000000149
resolution: 1.0
step_size: 0.10000000149
trans_epsilon: 0.00999999977648
max_iterations: 30
I can not know what frame_id I’m missing
@amc-nu Edit with new info, full .launch file, I have to had something more, but just should be sufficient to get localization.
<launch>
<group>
<machine name="ProcPC" address="192.168.20.110" user="greendog" env-loader="/home/greendog/Autoware/ros/devel/env.sh" default="true" timeout="10" />
<!-- load PCD -->
<arg name="area" default="noupdate" />
<node pkg="map_file" type="points_map_loader" name="points_map_loader" args="$(arg area) /home/greendog/AutowareData/CircuitMap/pointcloud/Circuito.pcd" /><!-- Lanza el launch del GPS Trimble -->
<!-- <include file="$(find nmea_navsat)/scripts/nmea_navsat.launch"> -->
<arg name="port_GPS" value="/dev/ttyS1" />
<arg name="baud_GPS" value="115200" />
<!-- </include> -->
<node pkg="nmea_navsat_driver" type="nmea_topic_serial_reader" name="nmea_topic_serial_reader" output="screen" >
<param name="port" value="$(arg port_GPS)" />
<param name="baud" value="$(arg baud_GPS)" />
</node>
<node pkg="nmea_navsat_driver" type="nmea_topic_driver" name="nmea_topic_driver" />
<!-- Lanza el nodo de la IMU -->
<arg name="port_IMU" value="/dev/ttyS0" />
<arg name="baud_IMU" value="38400"/>
<node pkg="memsic_imu" type="vg440_node" name="vg440_node" >
<param name="port" value="$(arg port_IMU)" />
<param name="baudrate" value="$(arg baud_IMU)" />
</node>
<!-- Convierte el quaternion de la IMU a Euler -->
<node pkg="topic_tools" type="transform" name="quaternion2euler" args="/imu_raw/orientation /euler geometry_msgs/Vector3 'tf.transformations.euler_from_quaternion([m.x, m.y, m.z, m.w])' --import tf" />
<!-- Lanza el launch del Velodyne -->
<include file="$(find velodyne_pointcloud)/launch/velodyne_vlp16.launch">
<arg name="calibration" default="/home/greendog/Autoware/ros/src/airportshmi/extras/VLP16db.yaml"/>
</include>
<arg name="device_ip" default="192.168.10.201" />
<arg name="frame_id" default="velodyne" />
<arg name="manager" default="$(arg frame_id)_nodelet_manager" />
<arg name="port" default="2368" />
<arg name="read_fast" default="false" />
<arg name="read_once" default="false" />
<arg name="repeat_delay" default="0.0" />
<arg name="rpm" default="600.0" />
<arg name="cut_angle" default="-0.01" />
<arg name="pcap" default="" />
<arg name="calibration" default="/home/greendog/AutowareData/VelodyneCFG/VLP16db.yaml"/>
<arg name="min_range" default="0.4" />
<arg name="max_range" default="130.0" />
<arg name="model" default="VLP16"/>
<arg name="topic_name_velodyne" default="points_raw"/>
<!-- start nodelet manager -->
<node pkg="nodelet" type="nodelet" name="$(arg manager)" args="manager" />
<!-- load driver nodelet into it -->
<node pkg="nodelet" type="nodelet" name="$(arg manager)_driver" args="load velodyne_driver/DriverNodelet $(arg manager)" >
<param name="device_ip" value="$(arg device_ip)" />
<param name="frame_id" value="$(arg frame_id)"/>
<param name="model" value="$(arg model)"/>
<param name="pcap" value="$(arg pcap)"/>
<param name="port" value="$(arg port)" />
<param name="read_fast" value="$(arg read_fast)"/>
<param name="read_once" value="$(arg read_once)"/>
<param name="repeat_delay" value="$(arg repeat_delay)"/>
<param name="rpm" value="$(arg rpm)"/>
<param name="cut_angle" value="$(arg cut_angle)"/>
</node>
<!-- start cloud nodelet -->
<node pkg="nodelet" type="nodelet" name="cloud_nodelet" args="load velodyne_pointcloud/CloudNodelet velodyne_nodelet_manager">
<param name="calibration" value="$(arg calibration)"/>
<param name="min_range" value="$(arg min_range)"/>
<param name="max_range" value="$(arg max_range)"/>
<remap from="velodyne_points" to="$(arg topic_name_velodyne)"/>
</node>
<!-- Lanza el nodo del veh\Ufffffffflo, villager6_interface -->
<arg name="wheel_base" default="2.502"/>
<arg name="mode" default="8"/>
<arg name="device" default="can0"/>
<arg name="loop_rate" default="100"/>
<arg name="stop_time_sec" default="2"/>
<node pkg="villager" name="villager6_interface" type="villager6_interface" output="log">
<param name="wheel_base" value="$(arg wheel_base)"/>
<param name="mode" value="$(arg mode)"/>
<param name="device" value="$(arg device)"/>
<param name="loop_rate" value="$(arg loop_rate)"/>
<param name="stop_time_sec" value="$(arg stop_time_sec)"/>
</node>
<rosparam command="load" file="/home/greendog/AutowareData/AutowareExecutiondumpedparams.yaml" />
<!-- base_link_to_localizer -->
<arg name="x" default="2.2"/>
<arg name="y" default="0"/>
<arg name="z" default="1.86"/>
<arg name="yaw" default="0"/>
<arg name="pitch" default="-0.0122"/>
<arg name="roll" default="0"/>
<arg name="frame_id_baselink2localizer" default="base_link"/>
<arg name="child_frame_id_baselink2localizer" default="velodyne"/>
<arg name="period_in_ms" default="10"/>
<node type="static_transform_publisher" pkg="tf" name="base_link_to_localizer" args="$(arg x) $(arg y) $(arg z) $(arg yaw) $(arg pitch) $(arg roll) $(arg frame_id_baselink2localizer) $(arg child_frame_id_baselink2localizer) $(arg period_in_ms)"/>
<!-- vehicle model -->
<arg name="base_frame" default="/base_link"/>
<arg name="topic_name" default="/vehicle_model"/>
<arg name="offset_x" default="1.2"/>
<arg name="offset_y" default="0.0"/>
<arg name="offset_z" default="0.0"/>
<arg name="offset_roll" default="0.0"/> <!-- degree -->
<arg name="offset_pitch" default="0.0"/> <!-- degree -->
<arg name="offset_yaw" default="0.0"/> <!-- degree -->
<arg name="model_path" default="/home/greendog/AutowareData/Model/VILLAGER_6.urdf" />
<arg name="gui" default="False" />
<param name="robot_description" textfile="$(arg model_path)" />
<param name="use_gui" value="$(arg gui)"/>
<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" />
<node name="robot_state_publisher" pkg="robot_state_publisher" type="state_publisher" />
<!-- vehicle info -->
<arg name="info_path" default="/home/greendog/AutowareData/Vehicle_info/VILLAGER_6.yaml"/>
<rosparam command="load" file="$(arg info_path)"/>
<!-- world_to_map -->
<node pkg="map_tf_generator" type="map_tf_generator" name="world_to_map" />
<!-- rostopic pub voxel_grid cfg -->
<node pkg="rostopic" type="rostopic" name="rostopic_voxelgrid" args="pub /config/voxel_grid_filter autoware_config_msgs/ConfigVoxelGridFilter '{voxel_leaf_size: 0.8, measurement_range: 200.0}'" />
<!-- voxel_grid_filter -->
<arg name="sync" default="false" />
<arg name="node_name" default="voxel_grid_filter" />
<arg name="points_topic" default="points_raw" />
<arg name="output_log" default="false" />
<node pkg="points_downsampler" name="$(arg node_name)" type="$(arg node_name)">
<param name="points_topic" value="$(arg points_topic)" />
<remap from="/points_raw" to="/sync_drivers/points_raw" if="$(arg sync)" />
<param name="output_log" value="$(arg output_log)" />
</node>
<!-- nmea2tfpose -->
<arg name="plane" default="19"/>
<node pkg="gnss_localizer" type="nmea2tfpose" name="nmea2tfpose" output="screen">
<param name="plane" value="$(arg plane)"/>
</node>
<!-- rostopic pub ndt_matching cfg -->
<node pkg="rostopic" type="rostopic" name="rostopic" args="pub /config/ndt autoware_config_msgs/ConfigNdt '{header: {seq: 0, stamp: {secs: 0, nsecs: 0}, frame_id: 'world'}, init_pos_gnss: 0, x: 45.0, y: 0.0, z: 0.0, roll: 0.0, pitch: -0.0122, yaw: 0.0, use_predict_pose: 0, error_threshold: 0.1, resolution: 1.0, step_size: 0.1, trans_epsilon: 0.01, max_iterations: 30}'" />
<!-- ndt_matching -->
<arg name="method_type" default="0" />
<arg name="use_gnss" default="0" />
<arg name="use_odom" default="false" />
<arg name="use_imu" default="false" />
<arg name="imu_upside_down" default="false" />
<arg name="imu_topic" default="/imu_raw" />
<arg name="queue_size" default="1" />
<arg name="offset" default="linear" />
<arg name="get_height" default="false" />
<arg name="use_local_transform" default="false" />
<arg name="sync_ndt" default="false" />
<node pkg="lidar_localizer" type="ndt_matching" name="ndt_matching" output="log">
<param name="method_type" value="$(arg method_type)" />
<param name="use_gnss" value="$(arg use_gnss)" />
<param name="use_odom" value="$(arg use_odom)" />
<param name="use_imu" value="$(arg use_imu)" />
<param name="imu_upside_down" value="$(arg imu_upside_down)" />
<param name="imu_topic" value="$(arg imu_topic)" />
<param name="queue_size" value="$(arg queue_size)" />
<param name="offset" value="$(arg offset)" />
<param name="get_height" value="$(arg get_height)" />
<param name="use_local_transform" value="$(arg use_local_transform)" />
<remap from="/points_raw" to="/sync_drivers/points_raw" if="$(arg sync_ndt)" />
</node>
<!-- /initialpose geometry_msgs/PoseWithCovarianceStamped '{header: {seq: 0, stamp: {secs: 0, nsecs: 0}, frame_id: 'map'}, pose: {pose: {position: {x: 45.0, y: 0.0, z: 1.86}, orientation: {x: 0.0, y: 0.0, z: 0.0, w: 0.0}}, covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]}}' " /> -->
<!-- vel_pose_connect -->
<arg name="topic_pose_stamped" default="" />
<arg name="topic_twist_stamped" default="" />
<arg name="sim_mode" default="false" />
<group unless="$(arg sim_mode)">
<node pkg="autoware_connector" type="can_status_translator" name="can_status_translator" output="log" />
<node pkg="topic_tools" type="relay" name="pose_relay" output="log" args="$(arg topic_pose_stamped) /ndt_pose"/>
<node pkg="topic_tools" type="relay" name="vel_relay" output="log" args="$(arg topic_twist_stamped) /estimate_twist"/>
</group>
<group if="$(arg sim_mode)">
<node pkg="topic_tools" type="relay" name="pose_relay" output="log" args="/sim_pose /current_pose"/>
<node pkg="topic_tools" type="relay" name="vel_relay" output="log" args="/sim_velocity /current_velocity"/>
</group>
<!-- MQTT -->
<arg name="use_tls" default="false" />
<node name="mqtt_bridge" pkg="mqtt_bridge" type="mqtt_bridge_node.py" output="log">
<!-- <rosparam command="delete" param="" /> -->
<!-- <rosparam command="load" file="$(find mqtt_bridge)/config/config/demo_params.yaml" /> -->
<rosparam command="load" file="/home/greendoog/Autoware/ros/src/mqtt_comms/comms_params.yaml" />
<rosparam if="$(arg use_tls)" command="load" ns="mqtt" file="$(find mqtt_bridge)/config/tls_params.yaml" />
</node>
<!-- rostopic pub ring_ground_filter cfg -->
<node pkg="rostopic" type="rostopic" name="rostopic_ring_ground_filter" args="pub /config/ring_ground_filter autoware_config_msgs/ConfigRingGroundFilter '{sensor_model: '16', sensor_height: 1.86, max_slope: 15.6, vertical_thres: 0.08}'" />
<!-- rostopic pub twist_filter cfg -->
<node pkg="rostopic" type="rostopic" name="rostopic_twist_filter" args="pub /config/twist_filter autoware_config_msgs/ConfigTwistFilter '{header: {seq: 0, stamp: {secs: 0, nsecs: 0}, frame_id: ''}, omega_limit: 1, lateral_accel_limit: 0.0, lowpass_gain_linear_x: 0.0, lowpass_gain_angular_z: 0.0}'" />
<!-- rostopic pub waypoint follower cfg -->
<node pkg="rostopic" type="rostopic" name="rostopic_waypoint_follower" args="pub /config/waypoint_loader autoware_config_msgs/ConfigWaypointLoader '{multi_lane_csv: '/home/greendog/Autoware/ros/test3_replanned_20.csv', replanning_mode: True, velocity_max: 20.0, velocity_min: 10.0, accel_limit: 1.5, decel_limit: 5.0, radius_thresh: 30.0, radius_min: 10.0, resample_mode: True, resample_interval: 4.0, velocity_offset: 3, end_point_offset: 4}'" />
<!-- rostopic pub velocity_set cfg -->
<node pkg="rostopic" type="rostopic" name="rostopic_velocity_set" args="pub /config/velocity_set autoware_config_msgs/ConfigVelocitySet '{header: {seq: 0, stamp: {secs: 0, nsecs: 0}, frame_id: ''}, stop_distance_obstacle: 20.0, stop_distance_stopline: 0.0, detection_range: 3.0, threshold_points: 3, detection_height_top: 0.2, detection_height_bottom: -3.0, deceleration_obstacle: 3.0, deceleration_stopline: 3.0, velocity_change_limit: 25.5, deceleration_range: 1.0, temporal_waypoints_size: 12.0 }'" />
<!-- rostopic pub initial_pose -->
<node type="rostopic" pkg="rostopic" args="pub /initialpose geometry_msgs/PoseWithCovarianceStamped '{header: {seq: 0, stamp: {secs: 0, nsecs: 0}, frame_id: ''}, pose: {pose: {position: {x: 45.0, y: 0.0, z: 1.86}, orientation: {x: 0.0, y: 0.0, z: 0.0, w: 0.0}}, covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]}}' " name="rostopic_initial_pose" output="log" />
</group>
</launch>
