Navigation recommendation for USV in ROS2 with GPS
I want to move a USV device with GPS based localization. Can you recommend any simulation environments and navigation stacks that can work in them? I need to integrate it in a simple way. Thank you for your recommendations…
I have used the VRX simulator in the past. I was working mainly in ROS Noetic with GPS, but the main VRX branch is now in ROS 2.
The best simulator for marine robotics is Gazebo. It has many capabilities that are useful to both surface and underwater robots, such as surface wave simulation and simulation of thrusters.
@mabelzhang is one of our experts on the topic.
Thank you for the information you provided @gbiggs @Gglaspell. I have examined the VRX system in detail. My main goal is to make an obstacle aviodance system. Are there any open source navigation stacks that you can recommend for this? I know a stack like Nav2 that can work on indoor systems and has tested a GPS-based application on a rover (a type of autonomous mobile robot that works outdoors). Since Autoware is designed entirely for cars, it seems like it will take a long time to manipulate it. I wanted to go with Nav2 here, but I did not see any examples or projects that were worked on. I do not want to choose the wrong paths. I need to define the navigation structure (global and local planners, obstacle aviodance structure, localization, synchronous communication infrastructure between packages) precisely and clearly. Since I could not see any project or work, I wanted to write here (as a navigation stack). Thank you in advance for your help.
The best people to ask about that are the people on this Discourse who are involved in maritime robotics. They have a lot of experience and knowledge about how to do things like navigation at sea.
