Autonomous boat control in GPS-based system
Hello Everyone,
Recently, I asked a question about a boat project I wanted to make for sea and water use on this link. @ gbiggs directed me to this topic. I thank him. I will repeat the question I asked there. There he made suggestions for simulation environments such as VRX system and Maritime. I had examined them before.
My main goal is to make an obstacle aviodance system. Are there any open source navigation stacks that you can recommend for this? I know a stack like Nav2 that can work on indoor systems and has tested a GPS-based application on a rover (a type of autonomous mobile robot that works outdoors). Since Autoware is designed entirely for cars, it seems like it will take a long time to manipulate it. I wanted to go with Nav2 here, but I did not see any examples or projects that were worked on. I do not want to choose the wrong paths. I need to define the navigation structure (global and local planners, obstacle aviodance structure, localization, synchronous communication infrastructure between packages) precisely and clearly. Since I could not see any project or work, I wanted to write here (as a navigation stack). Thank you in advance for your help.
I’m part of the team that developed VRX. While it does have some limitations, it was developed for the use-case you describe, prototyping perception and navigation (with obstacle avoidance) solutions. @caguero led the charge to upstream some of the VRX work into GazeboSim as you see in Maritime.
I have not seen a generalized, mature navigation stack for outdoor/maritime applications. (Would love to hear other’s experiences.) We recently did a custom radar-based obstacle avoidance project for a large USV, but unfortunately the client has kept this internal for now. I also am aware that @rolker has done some of this on commercial vessels with project11.
You might also look at the RobotX teams from 2002. As part of the competition they submit a technical paper. The documentation provide clues as to how others have solved the problem.
Thank you for the information you provided @bsb808. I will examine the resources you mentioned. I will also talk about a technique I have done and achieved results with. As you said, I would love to hear other experiences on this subject. Have a nice day :slight_smile:
Thanks for the mention @bsb808. We use Project11 here at the University of New Hampshire as a common framework capable of working on multiple types of ASVs. It was first developed on a CWorker-4, but has since been adapted to DriX and Seafloor System’s EchoBoat.
It currently runs on Noetic, but is being updated to work with ROS2 with plans of using NAV2.
nav2 is definately possible. Our company made an autonomous boat on the navigation stack back in the ros1 days here: https://nobleo-technology.nl/projects/fully-autonomous-wasteshark/
I can’t name names, but I knew a couple examples of this as well with Nav2
Thank you for your thoughts. I will inform you about this issue when I create the relevant infrastructure.
